Old 09-18-2007, 07:37 PM
nightrider nightrider is offline
will this tranny work in my car, i found another
http://cgi.ebay.com/ebaymotors/Subar...spagenameZWDVW
my car had been converted to a 02 wrx 5speed, that i blew up, will thiss one bolt right in, or be easily modified
Old 09-18-2007, 07:50 PM
The trans should go in fine, but you'll need to match the rear diff.
Old 09-18-2007, 08:25 PM
What Dave said....
Old 09-18-2007, 08:35 PM
do you think if i match the rear diff it will be a better gear ratio? does anybody kno the gear ratio? it isnt possible that it matches already is it? as u probly gessed i didnt do the 5mt swap, i bought it that way
Old 09-18-2007, 08:44 PM
The WRX uses a 3.545 rear, the same as the SVX.
The RS is not a 3.545, it's probably a 4.11?? You'll need to get a 4.11 (or whatever matches) rear out of a Legacy and swap your LSD into it. The info to swap the diff is either in the "how To's" or in a post somewhere?
Old 09-18-2007, 08:49 PM
when lookin at gear ratio specs is it the first gear ratio or the final ratio?
Old 09-18-2007, 08:50 PM
The final ratio....
Old 09-18-2007, 09:01 PM
ok i found out the 02 wrx was a 3.90 ratio and the rs was like huck said, 4.11, so would it be worth it to convert the car to a 411 ratio, is it benifial?
Old 09-18-2007, 09:18 PM
It's Just Eric's Avatar
Missing in action
Little more get up n go...Highway rpms may be a little higher, but it won't be annoying...Actually, it puts rpms closer to here the car loves to make power, so it can get you in trouble if you have a lead foot
R.I.P Cool Signature.
Old 09-19-2007, 05:13 AM
will the rs differential bolt up right were my old one was or do i need to take them apart and swap the gears?
Old 09-19-2007, 08:13 AM
You have to swap gears....
Old 09-19-2007, 08:54 AM
Speedklix's Avatar
Locker Link Solution
the seat gives me a hug easily from a stand still with 4.11
...like it loves it and asks for more.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 09-19-2007, 08:58 AM
Speedklix's Avatar
not a bad price, I should grab it as a spare
...but I would recommend to you, just get a wrx trans. save yourself the work of messin with the rear.
-Mike
[SIGPIC][/SIGPIC]
Old 09-19-2007, 07:36 PM
how about a 98 legacy trans? will it hold the power and bolt up right? and do you kno the gear ratio?
Old 09-19-2007, 07:56 PM
The only car that you can retain the stock SVX rear diff is a 2002-2005 WRX
Which have 3.90's in them, but a reduction of 1.1:1 to the rear so they run a 3.54 rear diff like the SVX....
the 98 Legacy manual will bolt up, and will either be a 3.90 or a 4.1 and will require swaping the rear diff gears.....get the numbers off the housing by the starter and look it up.
