Old 09-10-2007, 11:57 AM
JaySVX's Avatar
JaySVX JaySVX is offline
E85
As I look at the Stage 2, i see that you can go 2v7F for flex fuel, and gain the ability to run E85, with the size up 370cc injectors. What else, if anything, does one need to do to run E85. I heard that it was potentially damaging to some components of the engine, but nothing conclusive. Searched and searched, but all the information is scattered, so I was hoping to get a solid what you need from someone more experienced in the subject.
With E85 and 370cc injectors, should one also consider upgrading the fuel pump to something like a 255lph pump?
It makes less power per gallon vs gas, yet it increase power output of engine by 5%? How does that work?
Do you need to run the tank dry before pumping E85 into it? Or do you need to scrub it entirely? I wouldn't think that mixing fuels would be good, but I don't know.
I keep hearing the term "corrosive" when reading things online. What sort of components are susceptible to this corrosion?
When going with the E85 with 2v7F, you are already going to the 370cc injectors, z32 MAF for the 2v7 bit, is there anything else necessary to safely run E85?
Last but not least:
Is it really worth it?
Thanks much for the information, I'm not looking out for the environment specifically or trying to put the "hurt" on oil companies, I'm just curious about new technologies, what they can do, benefits, etc.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 09-10-2007, 12:17 PM
etz bseder etz bseder is offline
I am not sure what all you need to run the e85, but I don't think it would be worth it because even with the new cars with flex fuel capabilities, they are having trouble getting one to last for as much as the regular petrol powered ones.
'92 LS-L, exhaust, intake, audio, ecu 1V4?, hyper ground kit.
Next changes ... PAINT, fix engine problems, 4.44. (GONE)
'97 Impreza Outback Sport, magnaflow muffler, cold air intake, Alpine Type S, MP3/iPod deck, NGK wires, etc.(GONE)
