Old 09-09-2007, 04:10 PM
Sir. Nate's Avatar
Sir. Nate Sir. Nate is offline
SVXtreme
Urgent!
my tensioner on the alternator side is stuck, which way does the bolt turn to loosen it?!
Old 09-09-2007, 04:13 PM
What part are you trying to loosen? If it is the tensioner itself, you would turn it counter-clockwise to loosen the belt.
Old 09-09-2007, 04:33 PM
Sir. Nate's Avatar
SVXtreme
I've tried turning it counter clockwise, and it doesn't come loose. Maybe I'll spray the sliders with WD or something.
Old 09-09-2007, 05:15 PM
FIRST you have to loosen the 12mm lock nut on the face of the pulley that you are trying to adjust!
Old 09-09-2007, 05:38 PM
Thanks Tom. I Ass/U/me-d that he had done that and I should have mentioned it. Yes, what Tom said. If you don't loosen it, you won't be able to move the adjuster slide with the bolt.
Old 09-09-2007, 05:56 PM
kwren's Avatar
kwren kwren is offline
losen the nut on the pulley
then turn the adjusting screw ccw to loosen the belt tension, cw to tighten belt tension
the adjusting bolt has left hand threads
Old 09-09-2007, 05:57 PM
kwren's Avatar
when you are happy with the belt tension
tighten the nut on the pulley again!
Old 09-10-2007, 11:37 PM
Sir. Nate's Avatar
SVXtreme
I got it eventually, I just pulled the whole thing apart and cleaned it off very well, then I thought "maybe this front bolt has to be loose". thanks for the help. BTW. what would you all recommend for a squealing belt?
Old 09-10-2007, 11:48 PM
It kind of depends. There are a few things that could cause it to squeal. You might just need a new belt, but If its a newer belt and its squealing then you could try belt dressing. It might also be because you have the belt too tight or too loose. If you are going to buy a new one I'd recommend getting it from the dealer. I always buy mine from the dealer because they are only a few bucks more and they just look and feel soo much better than the ones you get at Autozone, Schucks, etc. Thats just my opinion though.
Old 09-11-2007, 01:29 AM
Sir. Nate's Avatar
SVXtreme
I did get a little liquid wrench and anti freeze on the belt while I was working on my car, it should just wear off I suppose?
