Bubbling Noise???
This may be coming from a sort of Vapor Lock, but I have noticed a somewhat Bubbling Noise in the right rear area from time to time.
It's not loud enough to show during driving, and it seems to be only on first startup of the day. Any input on what to check would be appreciated.
The Worm _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
hey weird I've had this noise a few times too, only after driving for a while and turning the car off at home
Brian |
Fuel gurgling in the tank. Normal life sounds, if my cars are any indication.
dcb |
Doesn't the fuel tank have a transfer pump? If so, I'd put even $$$ on that being your noise.
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:'89 Subaru XT6 Silver "Audrey" as in Hepburn '96 SVX LSi #767Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car. |
Mine makes the same noise. I always assumed it was the fuel tank depressurizing after the fuel pump turns off.
The noise is during startup, and there is a noise on shutdown, but that one comes from the Driver's side, and I assume that is a pump. I'll pay more attention to conditions in the next few days, since it's due to warm up again here. Edit.... It just sounds different from the outside. If you listen to the right rear quarter, you can hear it very clearly. It sounds more like a mechanical sound from the inside. I thought maybe I had the right rear diff letting go. Thanks again.
The Worm _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles Last edited by ShiuludeSVX; 09-11-2007 at 05:23 PM. Reason: don't need another post for this one. |
Not specifically an answer for the poster, but an answer to others.
As a three-time SVX owner (offender?) I will say that noises on startup and shutdown seem to be the norm. It's a Subaru thing... every Subaru I owned (including a Loyale and a Legacy) demonstrated this problem. There's a bubbling noise after the engine shuts down... well, I traced this in my SVX to the cooling and air conditioning systems. They both do it, and cause slightly different noises. A slight hissing/bubbling noise is the A/C. A deeper bubbling noise is the cooling system. Now, a bubbling on startup is usually the same thing. Bear in mind though that I have not encountered it being audbile outside the car... at least not significantly (maybe I didn't get out of the car fast enough). I would get concerned about a noise that's loud enough to hear from outside the car... but anything from inside is probably relatively benign. Hope this helps put someones mind at ease.
Ich bin ein SVXer wieder My Rides: Red 1996 SVX LSi (Saffron) 2007 Yamaha FJR1300 (Kaitlin) Previously owned; green '95 L AWD (sold), black/pearlie '94 LSi (too many problems), Polo Green '96 SVX LSi (apparently notThe end of an era) Member #2 in the Yahoo! club, been here since the beta-testing days. In dire need of a cheaper hobby. |
I've been hearing it inside the car and outside the car if the hood is opened when im shutting her down... just assumed it was coolant/fuel/freon settling down for the night
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L Donating Forum Member In Good Standing JDM 4.11 Geared Transmission JDM 'ALCYONE' Rear Panel JDM 'BOXER' Eingngine Cover JDM 'SVX' Hood Badge L-Edition Suede Rear Seats |
Yeah, that's sort of the sound I was describing. It may be nothing... as I said every Subaru I've ever owned did this and I never had a problem.
Hope that helps ease your mind a little.
Thread Tools | |
Display Modes | |
