Old 08-27-2007, 12:03 AM
nightrider nightrider is offline
fog lights and rear windsheild washer
how do you change the fog light bulbs, one of mine died now im basicaly blind at night
also the hose barb where the rear washer fluid goes through the window snapped off, can i change that whole assembly, rite now if i push the button i soak the people in the back seat, funny yes till i realized my interior got soaked too(the little plastic cover is missing, probly how it broke in the first place)
Old 08-27-2007, 03:33 AM
Sir. Nate's Avatar
Sir. Nate Sir. Nate is offline
SVXtreme
for the fog light bulbs, you unscrew the covers behind the lenses(the ones closest to the radiator) and then switch 'em out. as for the rear window washer, i'm having the same dilemma.
Old 08-27-2007, 05:48 AM
dcarrb dcarrb is offline
Actually, the headlight bulbs have a twist-fit collar, but the fog lamp bulbs are held by a spring clip. These are right beside the radiator, so you'll probably want to do the swap with a cold engine.
I'm pretty sure you can buy just the ring to which the rear washer fluid tube attaches.
dcb
Old 08-27-2007, 06:27 PM
Yes, you can buy another ring for the hose to fasten to. It gets brittle after a while and breaks. Post in the Parts wanted section and somebody may have one. Good luck.
Old 08-27-2007, 08:23 PM
ridered777's Avatar
Finally HAS a 3rd pedal!!
I hope your fog's are plug and play like they're supposed to be. Word to the wise, unplug your neg. Bat. cable when changing them.
I just gone done doing mine and went from one not working to both not working . Not only are they a pain in the ass to get at, but when changing the one on the pass side (2nd one done), I got a spark upon connection. I then decided to unplug the neg cable and finished the job. Headlights still work, but no response from the fog's. Light on the dash still lights up. It's too late to start chasing wires, and its only fog lights... I just wanted to get 'em going because my HID's should be in soon.
-Craig
Old 08-28-2007, 03:22 PM
immortal_suby's Avatar
Thread Killah
I did the same thing recently.
Open them back up and look for the wire that you plug in to be pulled out some and possibly grounding against the housing - did you blow the fuse too? 4th from the front, top row. The light on the dash will still light up even if the fuse is blown.
Locker Link
2015 BRZ Limited 6MT
