Old 05-31-2007, 05:27 PM
Daber Daber is offline
95 SVX LSI parts needed
I'm trying to get my SVX going after a couple of years for my son.
The shop says I need a new driveline, front passenger side calipers, power seat fuse/module, and a power window fuse/module(the ones under the seat.
I suspect I may end up needing more, but that should get it going for now. To try to keep the price reasonable and avoid parting it out I'm looking for good used parts at a reasonable price.
Any help or ideas would be appreciated.
Old 05-31-2007, 06:43 PM
cdvs cdvs is offline
The meaning of 'driveline'? Whether it means axle (there are 4, one for each wheel being driven) or driveshaft (one AWD only) these are not parts that go bad sitting.
I personally wouldn't install used calipers. They should be replaced in sets to maintain even braking. Rebuilts are around $100 each net.
There is a relay and a circuit breaker under the driver's seat that controls the windows, power seat and moon roof. The relay is commonly available. The circuit breaker can be replaced with a generic from Advance Auto or other supplier.
Good luck!
Old 05-31-2007, 07:24 PM
It's Just Eric's Avatar
Missing in action
See if Earl (ensteel)can help you out..Im pretty sure he has a parts car...and with 13 other svxi, I have a feeling he could lend more insight into your "Drive line" problem.
Driveline...wtf is driveline? somehing tells me the shop you took your car to is a little clueless
R.I.P Cool Signature.
Old 05-31-2007, 08:20 PM
Good luck!
My bad,
I meant driveshaft. I quess the brain turned of before the fingers
The mechanic said one was available for $160 and the other was not available. Is there a part number for the relay and breaker? By readily available are we talking Schucks, or Subaru?
Does the generic circuit breaker just plug in, or does it require rewiring?
Old 05-31-2007, 08:29 PM
sicksubie's Avatar
Why do you need a new driveshaft???
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 05-31-2007, 08:32 PM
I'm getting vibrations at all speeds. The mechanic said it was coming from the driveshaft.
He said the u joints were freezing up due to sitting so long.
Old 05-31-2007, 09:09 PM
Originally Posted by Daber
My bad,
I haven't checked for part #s or availability at Subaru, but try surbaruparts.com. Readily available means local auto parts store, but I don't know Schuck's. Generic requires plugging in the existing wires, unless the connections are corroded no rewiring should be needed.
