Old 03-25-2007, 11:37 AM
LiquidForce LiquidForce is offline
Send a message via MSN to LiquidForce
Talking Another 5spd SVX is on the road
I finally got it all together and was able to drive the car today. At first I could only get the clutch pedal to work and get the car into 2nd because disengagement point was right at the floor. I adjusted the rod as much as I could and now it is just off the floor and I am able to get into all the gears. I would still like to raise it a little more but at least it works.
Out of curiosity, if you have a hydraulic set up where is your disengagement point?
Old 03-25-2007, 11:43 AM
glad to hear it... It should release a little bit off the floor but usually some adjustment is needed. Did you use any spacers between the clutch master cylinder and the mounting studs??
tom
Old 03-25-2007, 11:57 AM
I did not use any spacers. Seems like using spacers might make the problem worse. I think what I need to do is get the master cylinder closer to the pedal box so there is a little preload on the cylinder.
Old 03-25-2007, 12:08 PM
thats exactly what needs to happen. Check to be sure there isn't anything keeping that from happening now before you go out and get anything... That is a stock pedal box just with the upper mounting points changed. check it out
Old 03-25-2007, 12:18 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Tom out of curiosity what did you do with mine? How does clutch engagement feel?
Brian
Old 03-25-2007, 02:13 PM
its perfect... just that your stage 2 is a little grabby but once you learn it, you will be fine
tom
