Old 03-18-2007, 10:44 PM
richardstanley's Avatar
richardstanley richardstanley is offline
Lover of Alcyones
5 sp swap
Hey, i was thinking about piecing a 5sp swap together, if anyone's got anything let me know
Old 03-19-2007, 05:37 AM
Hey Richard...
Good to see you over here too....
Old 03-19-2007, 11:04 AM
Lover of Alcyones
Thanks huck Finally got an svx, thats my 8th alcyone, first svx
Old 03-19-2007, 11:41 AM
What do you need?
tom
Old 03-19-2007, 03:52 PM
Lover of Alcyones
Basically everything at this point. I think i could find a tranny and dif, but definitely the interior parts of it i will need, shifter, boot, cables?
Old 03-19-2007, 08:48 PM
what kind of transmission fo you want to run?? if it is a cable, I can whip you up some pedals and linkage in no time... I am waiting on some more X-members to get here and I can make a few more of them as well
tom
Old 03-20-2007, 04:59 AM
Richard,
There is a list of things you'll need to do a cable type installation in my write up (link in my sig)
Old 03-20-2007, 08:07 AM
Lover of Alcyones
Would either tranny (imp vs leg) have an advantage? Or is it the same damn thing? What do you guys think bout this linky
Current:
95 svx Ls-L (Black)
91 5sp awd xt6 (red)
Had:
91 xt auto awd(lt blue)
85 xt 4wd turbo 5sp(blue/white)
86 xt 2wd turbo 5sp(black)
85 xt 4wd turbo 5sp(silver/white)
89 xt AWD 5sp (white)
85 xt 4wd turbo 5 sp sold to Zukiru (silver)
86 xt turbo 2wd 5sp (silver/black)
Old 03-20-2007, 08:17 AM
The Legacy's and Impreza's run the same trannys, but can have different final drives....and the Impreza rear diff won't work with the SVX LSD carrier, so the rear diff needs to come from a Legacy.
Old 03-20-2007, 06:31 PM
JaySVX's Avatar
JaySVX JaySVX is offline
I've seen that and wondered about it. It seems convenient, but that which is to good to be true, probably is. That particular system i believe is the hydrolic driven clutch, something i think that the guys doing the 5mt swaps are staying away from, for reasons unknown to me, but they seem to know their ****, so i'd assume it's for a reason. People were saying legacy tranny's gears are weaker too, so if you slam it to hard to often, you might break a gear.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 03-20-2007, 09:42 PM
I can supply everything for a bolt in 5spd. No welding is necessary. the small car kit has been known to be junk because of their use of crappy quality products and their reluctant will to start behind their products.
Old 03-21-2007, 05:15 AM
I like the cable version for it's ease in installation.
The onle downside to the hydralic unit is the extra work of installing the hydralice clutch system, clutch master cylinder, clutch slave cylinder, lines, and extra linkage to work the master cylinder.
With the cable version, it's just hook a cable to the peddal assembly, and hook the other end to the clutch fork..done
All the heavy duty transmissions are the Hydralic clutch types.
Old 03-21-2007, 06:27 AM
Lover of Alcyones
Yeah i had basically planned on doing cable, exactly because of that.. ease of installation. haha. Thanks very much for your help guys, i'll let ya know when i get some parts, or some money together..
Current:
95 svx Ls-L (Black)
Had:
Old 03-21-2007, 07:57 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Richard, I definately recommend Tomsvx for the parts. Haven't even seen what he did for us yet but knowing Tom and his anal exacting tendancies I know they will be built better and stronger than they need to be. His pricing is well below what lesser set ups are. Not sure what Motorsports does though as Dalye usually does good stuff too.
Old 03-21-2007, 08:28 AM
Aparently Dayle has been sending people my way as well.
tom
