Old 03-18-2007, 05:33 PM
shotgunslade's Avatar
summer wheels
Had an interesting day today, a lot of work accomplished, on a diverse set of tasks. Interesting contrast: chipping ice off my driveway with a pick in the morning, so the sun could melt a working area, then putting on my summer wheels in the late afternoon. First track day of the season is next Saturday at Lime Rock. Have to be ready.
Old 03-18-2007, 11:20 PM
Ah yes, Summer is coming . I cant wait to get to my summer activities, including the completion of a project . I had to finally use the Pearly at 4AM this morning, and the Miata was *literally* buried in the snow. The SVX climbed right through the high ice/snow barrier from which it was plowed behind.
I love your wheels, and I know that Ive said that before. Hope to see you with the car again at Reading!
