Old 03-02-2007, 08:25 PM
Jvan Jvan is offline
high performance headlight bulbs
Several months ago,maybe even a year ago, some one posted a thread of purchasing high performance bulbs from John Deere dealers. The price was very cheap and he gave the part number. I forgot the bulb number but it was the same bulb that someone on this site tried to do a group purchase. I tried to do a search but since I don't remember the bulb number I couldn't find it. The bulb was shaped alittle different than the original bulbs. Can anyone help find the thread.
Old 03-02-2007, 08:36 PM
I was going to do a group purchase on some bulbs. They weren't John Deere though. I will do some searching and try to let you know about them.
Old 03-02-2007, 10:20 PM
alltrac alltrac is offline
HIR2 bulbs(John Deere)
I searched john deere and it was the third thread down.
http://www.subaru-svx.net/forum/show...ght=John+Deere
Victor
Old 03-02-2007, 11:22 PM
pavanbabut's Avatar
are these bulbs better(brighter) than 9005 bulbs??
-Pavan
Old 03-03-2007, 07:54 AM
ssnsltd's Avatar
ssnsltd ssnsltd is offline
That's gona leave a mark.
yes.
there are a few threads on HIR bulbs. I have them in high and low beam.
David
96LSi 102k Laguna Blue
95 LS-L AWD, Safety package, 140k Polo Green
the Chick Magnet:
91 Justy GL EFI 4x4 154k (new motor @120k)
90 Yamaha V-Max
82 Yamaha XJ650LJ Turbo
My Diver Propulsion vehicle:
88 Jeep Cherokee 160k
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
85 XT AWD/4x4 Turbo Space Blue
Old 03-03-2007, 03:34 PM
Thanks, that was the tread I was looking for. I didn't realize they cam in high beam as well as low beam. I guess the bulb from John Deere would be a low beam. What is the high beam number HIR? Are they a worthwhile upgrade or just switch 9005/9006?
Old 03-03-2007, 03:38 PM
If they were the brighter of the two (9005), they could be used in both because of the projector type beams in the low beam lights. They would be brighter, but would not blind oncoming drivers.
Old 03-03-2007, 03:46 PM
I don't follow. I understand that the high beam 9005 can be used in the low beam by modifying the base but are you saying that the high beam HIR bulb could also be used as the low beam by modifying the base? Is the HIR2 the high beam or low beam bulb? And if it's the low beam bulb, what's the high beam bulb number?
Old 03-03-2007, 09:12 PM
I found the Group Buy Thread that I posted last year. I hope this will help.
I have modified the high beam bulbs and put them in for the low beams. I have never done any other modifications to bulbs than that. I have put all of the HID 9011 bulbs in all 4 locations. It really makes a difference.
Old 03-03-2007, 09:30 PM
pavanbabut's Avatar
Ok.. now I wanna really buy these.... before that, does getting these bulbs improve lighting over 9005 Silverstars that I currently have???
-Pavan.
Old 03-03-2007, 11:47 PM
ssnsltd's Avatar
They are MUCH better than SilverStars.
when I measured the SS bulbs, they actualy put out LESS lumens than the stock ones. I even bought a new stock bulb to check against.
The only down side to using the high beam HIR bulbs in the LB spot is they have a much shorter life (~1/3) of low beem HIR. (see thread link)
thread and web site for more info and bulb Specs:
http://www.subaru-svx.net/forum/show...&highlight=hir
http://www.hirheadlights.com/
David
the Chick Magnet:
90 Yamaha V-Max
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
Old 03-04-2007, 12:36 AM
pavanbabut's Avatar
I found 9011 bulbs for $18.81 a piece at www.gmpartsdirect.com, but couldn't find 9012... will keep searching and will update if I find....
-Pavan
Old 03-04-2007, 01:04 AM
ssnsltd's Avatar
-Pavan
I don't see where they are the HIR- just 9011 base/type bulb. Make sure you ask them
David
the Chick Magnet:
90 Yamaha V-Max
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
Old 03-04-2007, 01:11 AM
pavanbabut's Avatar
Aren't Toshiba 9011 Bulbs = HIR 9011?? becos those are the ones that are used in Chevrolet Avalanche....
-Pavan
Ooops... my mistake... these 9011 are non-HIRs....
Old 03-04-2007, 05:44 PM
To use the HIR 9011 in the lb projector, do you do the same modification to the base as is done to the 9005? I'll need to check with the John Deere dealer to find out if their bulb is a 9011 or 9012. I would think it's a 9012 since I can't see why you would need a high beam on a tractor.
