Old 02-12-2007, 05:31 PM
davew833 davew833 is offline
Short-distance tow?
I have to tow a dead SVX less than 3 miles... Is it worth taking all of the precautions mentioned, i.e.: FWD fuse in (no good: engine doesn't run), driveline disconnected, hire a flatbed, etc., or will it be OK if I do it slowly?
davew833@yahoo.com
Former 6-time SVX owner
Old 02-12-2007, 06:00 PM
It's Just Eric's Avatar
Missing in action
Well, do you have dolly or are you pushing it with cletus's pickuptruck?
If you have a dolly where two wheels are touching the ground, and the other two arent, its best to unbolt the driveshaft. Its quite easy...First, you get the car on the dolly, then you squeeze under the car and unbolt the driveshaft from the rear diff. Use a bungee cord to hang the driveshaft out of the way (tie it to the exhaust)
It's not so much tha you doiing anything slow is going to save your diffs, its the fact tha two wheels will be moving, and two wont
R.I.P Cool Signature.
Old 02-12-2007, 06:47 PM
No, not using a dolly, just a tow rope, so all four wheels will be on the ground. Tow company wants $70 to do it which I won't pay if there's little/no chance of damage.
davew833@yahoo.com
Old 02-12-2007, 07:24 PM
even a slow tow can mess up a trans if the engine isn't running... I would say blow the $70 to save more than that in transmission repairs.
tom
Old 02-13-2007, 04:54 AM
mikecg's Avatar
mikecg mikecg is offline
I thought it was fine to tow it with all 4 wheels on the ground.
Old 02-13-2007, 05:15 AM
It is if its a manual, but the auto needs the motor running to keep fluid pumping to keep it from getting hot.
Old 02-13-2007, 05:19 AM
Pay the 70 bucks.
Too much at stake.
Old 02-13-2007, 07:30 AM
SubaruKidSVX's Avatar
SubaruKidSVX SubaruKidSVX is offline
Do the $70... We did something like that once and it cost us alot more than what it would have cost to get a truck.
1992 SVX LS-L 77,000 Miles
1983 Alfa Romeo Gtv6
1990 Alfa Romeo Spider
1973 TVR 2500M
