Old 02-11-2007, 01:09 PM
AlcyoneDaze's Avatar
<-- custom hood ornament
Rebeading a tire
Well, this really has nothing to do with my SVX, but a buddy of mine drove his Jeep into a rather large rock and took the tire off the rim. Since its Sunday, no tire shop is open and we're trying to figure out how to put the tire back on the rim without any machine, can someone help out? We have an air compressor to fill the tire back up, but its off the bead. HELP!
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 02-11-2007, 01:13 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
yeah you need something to hold the rim in place and you need a pry bar to slide it over the bead..... its a HUGE PITA and it requires a pro touch to do it but it can be done.... i would recomend just waiting
- John
Old 02-11-2007, 01:17 PM
And it should be in the other forum.
well, I have a pry bar and an extra pair of hands, gotta get this jeep off the property by the end of the day and everything is closed in pennsyltucky on a Sunday
Old 02-11-2007, 01:18 PM
AND DANGIT! I don't even know which forum to post in! it's not 'General SVX' cuz its about a Jeep, this is MUCH more technical
Old 02-11-2007, 01:20 PM
do you have a forum for "NOT AT ALL SVX?"
maybe it should be moved to there...
Old 02-11-2007, 01:21 PM
I have seen people use a belt or rope to tie around the tires tread so that it will hold the bead close to the rim. It takes a lot of air to get it sealed. Good luck. No spare tire?
Old 02-11-2007, 01:23 PM
A couple pry bars, a big hammer, some lube (dish soap), and a lot of "GRRRRRRRRRRRRRR"-ing.
Old 02-11-2007, 01:41 PM
Is the tire still in place, just popped in???? My uncle used to use some starting fluid and a match to pop it on....
Do this at your own risk of course
Old 02-11-2007, 01:54 PM
SOme sick part of me really likes the above idea...
Well, we have a spare, but he managed to do this to both of his tires on the left side, one is destroyed along with the rim, the other is fine.
Can you expand on this belt/rope method? Just tighten it around the treads and turn on the air compressor?
Old 02-11-2007, 02:02 PM
Yeah, a ratchet strap wrapped around the circumference in the center of the tread. You will need as much of an airflow as possible. Good luck getting it to work with a 12v compressor. You'll most likely need something with an air tank.
Also make sure the bead/rim is slick, I've heard rumor of beer being used???
Old 02-11-2007, 03:19 PM
Yes jack the tyre off the ground, and take the valve core out so there will be a higher air flow.
Old 02-11-2007, 06:33 PM
wow, thanks agin everyone, we got the jeep outta my yard a few hours ago. The rope around the tire method worked after a lotta experimenting and a bigger compressor!
