Old 10-22-2006, 10:20 PM
matty169 matty169 is offline
Convert to rear wheel drive?
1992 SVX AWD. Front ring and pinion are shot. Can it be made into rear wheel drive easily? Thanks
Old 10-23-2006, 04:10 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
http://www.subaru-svx.net/forum/showthread.php?t=35610
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 10-23-2006, 09:50 AM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
$100 plus shipping gets a good used stock SVX front ring and pinion from a suby reman if you want to go that route.
Old 10-23-2006, 11:50 AM
BAC5.2 BAC5.2 is offline
Convert to a manual transmission and the swap from AWD to RWD is as simple as swapping out the center diff with a spooled collar.
I was RWD in my Legacy Turbo for a while. It's absolutely ridiculous how easily a high-power Subaru will destroy any resemblance of traction when RWD.
Note: If you have a blown ring and pinion, even being RWD will still turn the front differential. Unless you disassemble your axles and ONLY run the outer cups, you will have to leave the axles in the transmission which will cause the front diff to spin at road speed. The outer cups and axle nuts are what hold the wheel bearing together. If you leave the axles connected, gear bits will still fly every which way inside the transmission. With the automatic, since the front differential is seperate from the rest of the transmission, there is less chance of damage to the rest of the transmission from having the front diff pieces floating up front, but it's still not a good idea.
If I were you, I'd consider swapping the trans for a known good unit.
