Old 10-02-2006, 09:29 PM
gsrsol84mm gsrsol84mm is offline
Which Air Filter Is Best ???
What air filter is the best ? K&N or Green stock replacement or just remove the filter box and go with a cone free flow ?or ??? I will be installing the ECUTune stage 2 v6 and need to update the air filter.
I would appreciate any feedback.
Thanks - Wayne
Old 10-02-2006, 10:06 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
I've been using Dayle's stage 3 intake with Green filter. It works well and sounds awesome.
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 10-03-2006, 05:44 AM
dcarrb dcarrb is offline
Ditching the stock, cold air intake in favor of a set-up that sucks hot air from the engine compartment isn't likely to accomplish anything, except draining dollars from your wallet.
dcb
Old 10-03-2006, 05:59 AM
What do you suggest ? K&N replacement & ditch the breather box below or ?
Wayne
Old 10-03-2006, 06:57 AM
i never liked K&N-style oiled gauze filters - they don't filter well, and the oil fouls up your MAF sensor.
i tried the Perrin foam panel filter (got it free with a purchase) and like it a lot. it flows as well as a K&N, filters much better, and is re-useable. the "oil" it uses is VERY thick unlike the thin K&N oil, so there's no way it will end up on your MAF sensor.
Perrin makes them, and also AMSOIL. if you can't find one to fit an SVX specifically, the 2002 WRX uses the same size.
http://www.perrinperformance.com/pro...nel_filter.htm
http://www.pecuniary.com/synthetics/airfilters.html
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 10-03-2006, 10:25 AM
scoobymal's Avatar
scoobymal scoobymal is offline
Talking
Genuine Subaru STI panel filters are getting good results,same as the impreza,and drops straight in to the airbox.
Old 10-03-2006, 11:04 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
+1 I had one on my former SVX!
2006 Steel Gray WRX TR (sold)
