Old 08-22-2006, 05:00 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Clay bar, etc.
Does using clay bar on the finish ruin the clearcoat or strip it?
I want to detail my car but one of my buddies thinks the clay bar will remove the clearcoat too. Is this true? or is the bar safe?
Also what is a good product to use on the body to remove swirlmarks in the surface? I do not have a buffer, so I was going to do it by hand, but not sure what to use yet.
Thanks
1995 Subaru Svx L / AWD
Old 08-22-2006, 05:04 AM
Put underneath it the type of Nylon which is used to wrap food with... It may stick to the clearcoat but I doubt it will cause any damage..
Old 08-22-2006, 07:35 AM
msvx95's Avatar
It's just a phase
So you are saying not to actually let the clay bar touch the clearcoat surface itself.
Old 08-22-2006, 07:42 AM
Well it's better no to, use that thin Nylon I told you about... Got it???
It is used in Friges to cover food with.
Old 08-22-2006, 08:05 AM
msvx95's Avatar
It's just a phase
Got it....I shall give it a try....I think I'll buy the bar this weekend
Old 08-22-2006, 08:52 AM
Bwana's Avatar
Bwana Bwana is offline
*Special* Member
Send a message via AIM to Bwana
Putting the nylon under it completely negates the point of using the clay.
It's theoretically SUPER-fine sand paper, just enough to remove embedded crap in the paint.
It will not ruin the clear coat unless you do it with no lube. As long as you keep the area you're claying soaked (i just use the soapy water from washing the car), and you dont rub one spot like 500 times, you pretty much cannot damage anything.
[/COLOR][/COLOR]-Scott My Locker
2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14
2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14
1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65
1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07
1994 Pearl White LSi Bought: 2001? Sold: 2004?
Old 08-22-2006, 09:42 AM
msvx95's Avatar
It's just a phase
Will I know by the feel of it while rubbing as it is wet when it's smooth. Do I need a little elbow grease or should I just lightly rub the area? I'm not sure, I never tried this method
Old 08-22-2006, 09:51 AM
Don't use pressure, just float the clay over the wet surface. You'll feel and sometimes hear a change in the gliding.
Old 08-22-2006, 10:21 AM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
i was thinking about doing this, and this is the method i had been described as well. The clay bar will do all the work where it is needed.
phil
~Phil
Old 08-22-2006, 10:33 AM
msvx95's Avatar
It's just a phase
Okay I can picture what you are saying....does it need to be really soapy water or just a wet surface?....and wet as in soaked with the water constantly running on it or just a beaded up surface?...sorry for all the ?'s
Old 08-22-2006, 11:26 AM
Here is the link to the clay bar instruction video by Mother's. I use their products a lot and their clay bar is very easy to use. Use Mother's Showtime® or Meguiar's Quik Detailer® as a lubricant.
http://www.mothers.com/reelworld/mothersclay.html
Old 08-22-2006, 01:31 PM
momzsvx's Avatar
momzsvx momzsvx is offline
A mom with style ;-)
Send a message via Yahoo to momzsvx
Let me know if this works for ya....
MOMZSVX
92 LS-L parts
94-LSi My baby
95-(AWD) polo green T-Boned
Old 08-22-2006, 01:44 PM
Bwana's Avatar
*Special* Member
Dont waste money on using the QD as a lube...just use soapy water, and make sure it is always wet. If you feel the bar start to stick, you're way too dry.
Old 08-22-2006, 02:21 PM
PDSides PDSides is offline
Old Guy
You have plenty of advice on using a clay bar, so let me address your other question about removing swirls. You mention surface swirls, so I assume you have no swirls in the paint itself, which would mean sanding and refinishing to remove. For surface swirls, let me recommend Meguiar's Scratch X. I have found Meguiar's products to be safe and effective if used according to their directions. It is safe for clear coats and it does the job it says it will do.
Preston
Old 08-22-2006, 03:36 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Easiest way to get the work done, get in good with a local detailer. I have a local guy that does clay bar, polish, and paint sealer. The car looks great after. Its been a couple months since he's done it, I'm going to have him hit it up one more time before the up coming show.
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
