Old 08-22-2006, 01:02 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Dan, always enjoy reading your track stories. Looking forward to the next one.
PS: I didn't know you're so much taller than your SVX.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 08-22-2006, 05:36 AM
shotgunslade's Avatar
Yeah, trying to get the helmet under the sunroof means I have the seat tilted back so far, I'm almost lying down.
Old 08-22-2006, 08:39 PM
I hear you there. When I end up turning my silver into a track car, I will at least cut a hole in the headliner for my head to fit.... Damn being cursed with height
Old 08-27-2006, 07:25 PM
The Goat The Goat is offline
This explains quite a bit now that I see a photo of your car; I live about 5 miles from the track off Long Pond road (the road that the entrance to the track is on), and my wife called me one morning about 2 weeks ago as I'm on the way to work asking me what I forgot.
Me: "What?"
Wife: "I just saw you on the way back to the house."
Me: "You're hallucinating"
Wife: "No, I SWEAR I just saw a car exactly like yours going the other way. It was the same color as yours."
Me: "I doubt it."
It's nice living near the track, because you'll always see exotics wailing through the turns. I got behind an Exige on the way to the track once and watched him slice through the turns (until he disappeared in about 30 seconds) - those little things are just crazy.
Old 08-27-2006, 07:35 PM
That would have been Friday 2 weeks ago. Mine is emerald pearl.
Old 08-27-2006, 09:00 PM
Well, she was pretty darned close. Mine's Polo Green.
Of course, we must never speak of this conversation again. If she finds out she was right, I'll never hear the end of it.
