Old 08-16-2006, 09:05 AM
mikecg's Avatar
mikecg mikecg is offline
Originally Posted by -JJ-
I agree, i could animate those photos, nice and clsoe together, If that was digital, what camera were you using
I didnt take them. Someone else took them and posted them online. I just copied them.
Old 08-16-2006, 10:17 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Originally Posted by mikecg
I'd like to say there sold, but I got a slight situation. Saturday I'm leaving on the ship and we wont be back until October. Can you hold on to them until then?
Mike,
Sure. Just don't forget!
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-16-2006, 12:59 PM
Zeppelin's Avatar
Zeppelin Zeppelin is offline
Send a message via ICQ to Zeppelin Send a message via AIM to Zeppelin Send a message via Yahoo to Zeppelin
On a side note. I finally got a decent car to autocross. It's a 1988 Conquest TSi. 119K miles, new struts and tires. Currently it has either a clogged fuel filter of bad plug wires I think. I couldnt get it above 40MPH. Everytime the turbo started to build boost the engine would start missing. And the exhaust leaks. I paid $1200 for it. I figure I got all winter to get it set up. I just need to decide what class I want to run.
Check for boost leaks yet?
I'm like a Slinky.. Not really good for anything, but you can't help but smile when you see me tumble down the stairs.
http://stickyvinylgraphics.com/
Old 08-16-2006, 07:47 PM
mikecg's Avatar
I haven't checked for boost leak. I'm not suspecting a boost leak, because the gauge is reading good. I think it is most likely an issue with the fuel system. I replaced the filter and made some minor improvements. Here's were
I am currently at. I think it may be the Pressure regulator. I leave the key turned on but the engine not running (to allow the pump to build up pressure). The car will run awesome for about 5 minutes. Then it goes to crap. I have a pressure regulator on order now. Tomarrow I'm going to disect the on in it to see if I can find any obvious problems with it.
I accually go up to about 70MPH today before it crapped out again. I could be over boosting it too. Stock boost is around 8lbs. The gauge was showing 12lbs breifly.
