Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Engine Management
Old 07-27-2006, 12:41 PM
svxash's Avatar
svxash svxash is offline
ECUtune Stage 1 installed,found strange chip inside
Well I installed my stage one chip today and when I opened the ECU I found this inside. Anyway I called ECUtune and spoke with him about it and he had never heard of the chip. I'm going to send it to him and he said that he could read the chip to see what is on it. He thought it might have been a rebuilt ECU. The resistor in the J1 spot had been cliped at the top but was still in place as you can see in the photo.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 07-27-2006, 03:11 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Could it be one of those Australian power chips?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-27-2006, 05:31 PM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
Could be, but the one I had said Superchip on it and didn't have the little sticky note thing.
Old 07-27-2006, 07:10 PM
immortal_suby's Avatar
Thread Killah
could it be the subaru TSB chip like the on in my wife's old svx?
Locker Link
2015 BRZ Limited 6MT
Old 07-27-2006, 10:49 PM
svxash's Avatar
I don't think so because I believe those chips had printed F23... numbers on the label. The one in my computer had a hand written label that was F31...
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 07-30-2006, 01:43 PM
Still, it was a factory chip more than likely, at least that is my deduction
Old 07-30-2006, 02:05 PM
shotgunslade's Avatar
It looks like a Powerchip from the Australian company. They are of that configuration, just a chip, not an entire circuit board, like Ecutune. I had one for my 92 Teal that I bought in 1998. Put it in and noticed exactly 0 difference. At that time, they were a very ad hoc, built it in their garage kind of informal opertation. Set me back $400, not well spent.
Old 07-30-2006, 05:45 PM
svxash's Avatar
After installing the ECUtune chip and driving it a few days I'm noticing more of a difference. The flat spot seemed to dissapear right away and now the more I drive it the better it gets.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 07-31-2006, 05:46 PM
longassname's Avatar
Just some dude.
did yours have the same type of hand written label on it?
Old 07-31-2006, 08:05 PM
Don't remember clearly. It did have some kind of label. I seem to remember it was a paper stick-on, wasn't a Powerchip label, just some type of identificatrion number.
Old 07-31-2006, 08:07 PM
Just some dude.
how confident are you that the chip he found and pictured is a powerchip.
Old 08-01-2006, 02:28 PM
Mine had a hand written label on it before I installed the Stage 1 chip. The bead was also crushed.
Old 08-01-2006, 02:30 PM
Just some dude.
do you know what yours was
Old 08-01-2006, 06:26 PM
No, it was in there when I got the car. I sold the chip to someone on the network but unfortunately cannot remember who.
Old 08-01-2006, 06:30 PM
Just some dude.
maybe the guy svxash bought his car from lol
