Security Module location needed ASAP
Hey all, I am at work right now (Best Buy) having one of the technicians install a new viper 350hv security system, but the technicians can't find what they need. I have done a few searches, and spoken with SVXFiles, and still cannot narrow down what I need for the job. The Tech's seem to think that they have to take apart the dash to get to the security module, which I will not allow them to do. Could someone please respond as quickly as possible, and either give me a resource to look up the information, or give me a description of what to find and where...I have them looking underneath the glovebox right now. Thanks
Speed of response is appreciated! -Andrew
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD* 2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp). Charlottesville, VA Represent! (voted #1 place in America to live!) http://www.subaru-svx.net/photos/user.php?Amazonparrot |
I'm pretty sure the security module is behind/above the glovebox on '92s and under the package shelf on later models.
dcb |
It is behind the glove compartment. You have to take off the glove box door and a lot of screws that hold the inner panel (the box itself). You will see the two bolts that hold the security module to the mounting bracket.
Factory Service Manual 6, section 6.2, page 29 .
Here's a link to the How-To doc I mentioned to you on the phone:
http://www.subaru-svx.net/photos/files/How-To/14371. Good luck! -Chike
document type?
Hi...I am trying to open this linked file, but cannot determine the app required. I tried word & adobe...no joy. Did we lose this doc after the recent hardware upgrade?
svxist 96 - LSI Laguna blue 94 - L fwd - laguna blue (donor car) |
That file (14371) is a jpg. Save it to your PC and rename it to have the extension .jpg
Then you can view it. It's just the diagram showing the locations of various modules in the SVX. There are quite a few files in the lockers that lost their extensions. .jpg is a good bet to try first. .gif is a good one to try second.
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
renaming with a jpg extension works fine...thanks for the help!
Thread Tools | |
Display Modes | |
