Old 01-29-2006, 09:47 PM
THAWA
Rear Spring diameter, Rear strut mount bolt pattern
Does anyone know any of this information? It doesn't matter if it's ID or OD, I just need to know the diameter of the stock rear springs (top diameter moreso than bottom diameter), and the bolt pattern of the stock rear strut mounts.
Old 02-02-2006, 07:33 PM
THAWA
bump567890
Old 02-02-2006, 07:45 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
PM Mychailo I think he knows the answer.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-06-2006, 10:57 AM
THAWA
No reply from mbtoloczko.
I measured the rear strut top bolt pattern. It's an equilateral triangle with sides roughly 4". VERY good news! . Spring diameter doesn't really matter anymore, but I've got a hunch (after inpertrating some half ass info) it's around 100mm ID . New suspension soon!
Old 02-06-2006, 11:35 AM
mbtoloczko's Avatar
sans SVX
I measured the strut top bolt pattern. It's an equilateral triangle with sides roughly 4". VERY good news! . Spring diameter doesn't really matter anymore, but I've got a hunch (after inpertrating some half ass info) it's around 100mm ID . New suspension soon!
I saw your message, but didn't have time over the weekend to do it. I don't know the exact measurements on the strut top bolt pattern, but I know that the front and rear patterns are different, and that the front is not an equilateral triangle.
Mychailo
Visit my locker
Old 02-06-2006, 01:04 PM
THAWA
Snap! I meant the rear for all of this stuff. I could have sworn that I put that in the original post, but I guess not. At any rate, with an inch ruler (mm would be better but I don't know where it is :\) the fronts are an isosceles triangle with the base being 4.25" and the legs being 5". I don't understand the reason for this, other subarus have an equilateral triangle with all sides being 5". Does the isosceles-ness aid in some way? Never the less, a new (MUCH cheaper) suspension option will be verified in a week or so, after I order a replacement front strut mount for my noisy one.
Also, the SVX rear struts are hella easier to take out than any other new gen non-wagon subarus. You have a straight shot to the bolts, instead of having the rear deck area in the way.
