air flow in PCV system
I'm setting up a ram-air system, and I just want to make sure that I understand the air flow through the entire PCV system so that I can make any changes to the PCV system that might be necessary to keep from possibly pressurizing the crank case and blowing oil out the seals. From what I can see, it looks like the PCV valve is set up to use manifold vacuum to pull air through the PCV system. And it looks like the PCV valve can either pull air from the crankcase or from a breather pipe attached to the intake duct coming off the airbox.
How are the turbo and SC people dealing with the PCV system? Is the PCV valve even utilized on LAN's SC system?
The pcv is spring loaded to close on non vaccum points ....
Edit: being dumb realized rarm air= more pressure ...I'm off to bed tonight now.
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
Hmmm, you may want to vent the PCV to atmosphere. I think LAN has his before the supercharger. For just ram air I wouldn't worry about it.
That's what I'm thinking now.
Guys, I have ahard time finding my pcv valve.... can you point out where ut is? is there just 1 or 2?
Pull the lower(central ) cover off of your intakeand stick your finger in the hole and then move it towards the front you should be able to find it.
thanks!!!!!
