Old 01-17-2006, 02:06 PM
pavanbabut's Avatar
Question Whts happening with my steering??
Hi,
Got a new problem. My steering is acting crazy now a days . Here is the exxact problem.
The steering makes a lot of screeching noise when the car is started in the morning. At this time the steering is like a hell to turn (very tight) and when i try to turn it and make it loose or to get rid of noise, in this process of rotating whenever the steering becomes tight the steering, Battery, stop-lamp and ABS light up on the dashboard.
After the car is heated up or after sometime of running the car, the noise dissappears and the steering wouldnt be tht much tight as it was at the time of cold start. But will show up sometimes when I try to trun the wheel full on either sides (completely right or left). Turning left is little tighter than turning right.
The other symptom is, the steering is rotating freely (freely deosnt mean like a good steering, but comparitively free from idle) when i give some revs, but while idling it is acting tight.
Using Valvoline-Synthetic p/s fluid.
Any ideas/suggestions? Thinking of replacing the pump or rebuilding it with any necessary parts.
thanks,
-Pavan.
Old 01-17-2006, 02:26 PM
NeedForSpeed NeedForSpeed is offline
Have you checked the fluid level?
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 01-17-2006, 02:27 PM
dcarrb dcarrb is offline
Have you checked the drive belt condition/tension? A slipping belt will screech under load, as when you turn the wheel, and since the same belt drives the alternator, when it's slipping, the ALT isn't turning as fast as it should, causing the dash warning lights to illuminate.
If the belt's not worn or loose, the slippage could be caused by the idler pulley or PS pump is trying to seize.
dcb
Old 01-17-2006, 02:34 PM
pavanbabut's Avatar
Hi Ron,
the fluid is upto to the mark and I have replaced it last week with new fluid.
thanks,
-Pavan.
Old 01-17-2006, 02:40 PM
pavanbabut's Avatar
dcb
Coming to belts. My A/C belt is not good but works and will replace it next week. Coming to steering belt, it is in good condition and not too tight and not too loose. But as far as i remember there is some oil dripping drop by drop slowly, if I try to trun the steering either too fast or full turns. Have to figure out the source of dripping. The dripping seems just b/n the tranny and the exhaust pipe behind the engine (hoping it is from p/s column or something). Checked all the steering hoses and clamps, all r in good condition.
Thanks
-Pavan.
Old 01-17-2006, 03:33 PM
Hope you don't have issues with your steering rack
Old 01-17-2006, 03:49 PM
pavanbabut's Avatar
Old 01-17-2006, 04:02 PM
Old Fogey
"Using Valvoline-Synthetic p/s fluid"
Hate to tell you Pavan, but the Steering Box uses ATF, not p/s fluid. Check the How To section under Steering/Flushing etc.
Glenn
Old 01-17-2006, 04:23 PM
There are several posts on this subject.
- belt problem
- pump problem
- pulley problem
- bearing problem
Old 01-17-2006, 04:28 PM
Old Fogey
- belt problem
- pump problem
- pulley problem
- bearing problem
How about wrong fluid problem?
Glenn
Old 01-17-2006, 04:42 PM
Unless you put motor/diff oil in there it shouldn't cause those problems.
Dexron 2/3 or even actual PS fluid will work.
Old 01-17-2006, 05:51 PM
Old Fogey
uh, ok..........
Old 01-17-2006, 06:11 PM
pavanbabut's Avatar
- belt problem
- pump problem
- pulley problem
- bearing problem
I wouldnt mind checking these one by one, if you can gimme some steps to follow for it. I will try changing the fluid too in case.
-Pavan
Old 01-17-2006, 06:23 PM
- remove belt & inspect for missing chunks, wear
- turn the PS pulley, Alt pulley and tensioner by hand. All should spin free and quiet.
- inspect crank pully for separation
If all appear to be ok put the belt back on and tighten properly. If it still squeals tighten a bit more. (repeat as necessary)
Old 01-17-2006, 08:43 PM
pavanbabut's Avatar
Thanks David, I will do this on the weekend. Before tht I have to check for the dripping oil.
-Pavan
