car shakes over 45mph
well i dont realy have a clue whats going on but i think it has something to do with the tranny but i hope not i just spent $3000 to fix the thing.
the car drive fine untill you get over 45 mph and the you can feel the hole car shake. last night i went to get some food and at like 30 or 35 mph it sounded like drive shaft or something right onder the center conscol was hitting something it was like a tapping sound but it was not a loud sound i had to turn down the radio and the heater to hear it
01 subaru legacy 5sp 97 J-spec kl-ze 5sp ford probe the best of them all the 92 lsl svx amost 100,000 mile |
go underneath your car and check that area between the cross member and the tranny... If everything seems to be in order then you have a bad wheel.
I had a bad shake one time too in my Silver (why did I sell that) and it just needed tires balanced.
But with someone just being under your car......I don't know.....doesn't sound good. Keep us posted please.
1996 SVX LSi Yellow/White fade custom paint. 1992 SVX LSL Pearl 1992 SVX LSi Ebony 1992 SVX LSL Silver - parts |
You should take it back to the shop that serviced the transmission, ASAP.
dcb |
1984 GL Brat (Lurch) 1988 GL RX (Badtz-Baru) 1989 AWD XT6 (Smoke) 1994 SVX [Emerald Pearl] |
Is the driveshaft rubbing on the heat shield? Perhaps the U-joints are worn in on the driveshaft?
get you tires balanced first, then shoot from there, the speed relative thing makes it sound like tires
Tom |
Checking the wheels and tires sure wouldn't hurt, but that wouldn't explain the noise from the transmission hump, unless there's just something loose and rattling. Recent tranny overhaul + noise from the drivetrain + a pronounced balance issue = take it to the guys who pulled the transmission; the sooner; the better. Let THEM rule-out mount/driveline trouble.
dcb |
Does it only shake when the torque converter locks up? I had this happen on my 95 and it turned out the a bad coil pack was causing it to run rough and after TC lockup, it would be transmitted thoughout the car.
Another thought is the dogbone engine mount back by the intake. on my 92, it was disconnected and caused the engine to tip back and forth too far causing the tranny tail shaft to hit the bottom of the car, but that was mainly in reverse. Dan |
i got the tire balanced and that was not the problem.
i check the bearing tht hold the drive shaft in the center is worn and the bracket shakes i tryed to tighten the bolts but there as tight as they will go so i was think that if i put a couple of washers on the bolt that could make the bolt tighter.
ok i check it out and you can move the drive shaft and it will go back. but if you shake the drive shaft a little harder you can feel the whole bracket move.
i dont wanna take it back to the tranny people a.k.a cottams trans. it is out of the 1 year 12,000 mile warrenty and they were a rip off to begin with. i dont think they did all that i asked for but how m i to tell them what they did and didnt. they gave me the run around every time i have been there with my car
That said, it seems to me you may need to enlist a pro to troubleshoot your problem, anyway. Good luck. dcb |
