Old 01-16-2006, 01:33 AM
MpSVX's Avatar
MpSVX MpSVX is offline
SVX...It's the only opption
tire question
what is the deal with the 55mm offset, what exactly is it. Is it like the camber of the alignment. I'm confused because I see people posting there tire size with a different offset? just wanted some clerification. to late right now to search anymore. thanks
mike
looking for svx
former owner-
94-L 124,000(traded it when tranny went bad)
Old 01-16-2006, 09:22 AM
mbtoloczko's Avatar
sans SVX
Offset refers to the rims. Here is the famous TireRack sketch showing wheel offset.
<http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101>
Here is the TireRack tech info webpage:
<http://www.tirerack.com/about/techcenter.jsp>
The SVX has positive 55 mm offset which is higher than about 98% of the vehichles produced. The high offset limits your choice of rims what will fit the SVX. Its not necessary to stay at 55 mm if you buy an aftermarket wheel, but any rim with an offset lower than 38 mm will probably cause the tire to rub the fender (especially if a wide tire is used).
Mychailo
Visit my locker
Old 01-16-2006, 10:56 AM
mike
This picture is from the How-To Documents and shows what offset it.
Old 01-16-2006, 12:39 PM
MpSVX's Avatar
got to learn some time
Ok so the offset is the distance from the center of the tire to the inside of the rim or hub mount. Ok now another question so a 17in rim at say 7.5
( same style rim )could have more than one off set?
looking for svx
former owner-
Old 01-16-2006, 01:10 PM
I guess I don't understand your question.
mbtoloczko's Avatar
sans SVX
Rim manufacturers often make the same style/size rim in several different offsets.
Mychailo
Visit my locker
Old 01-16-2006, 01:12 PM
MpSVX's Avatar
Ok thats what i wanted to know, so then it is the bolt pattern that is the issue with not a lot of selection of rims
looking for svx
former owner-
Old 01-16-2006, 02:52 PM
mbtoloczko's Avatar
sans SVX
The low selection is due to the offset required. If you're willing to settle with a 38 mm offset, you'll find a pretty decent selection, but if you want an offset closer to the factory spec, the number of choices in rims goes way down.
Mychailo
Visit my locker
Old 01-16-2006, 06:23 PM
MpSVX's Avatar
38mm
would the 38 mm cause any problems too the car??
looking for svx
former owner-
Old 01-16-2006, 07:31 PM
mbtoloczko's Avatar
sans SVX
As the offset gets further and further from the factory spec of 55 mm, an increase in brake-induced steering wheel pull and tramlining will be felt. If you don't drive aggressively, you may not notice it. Some of the pull can be removed by tinkering with wheel alignment settings, but its better to stay close to the factory wheel offset.
Mychailo
Visit my locker
Old 01-19-2006, 01:51 AM
MpSVX's Avatar
thanks for the advice
looking for svx
former owner-
