Old 01-12-2006, 11:06 AM
Michael Blue's Avatar
Michael Blue Michael Blue is offline
Sold. :'-(
Trans service, recommendations needed...
Hi!
My trans has been acting funny (go figure) and I'm going to flush it out and change the fluid and filter next week.
I was wondering what your recommendations are for fluid...I am planning on synthetic, unless there's a reason not to, but is there a weight or brand you guys prefer?
Thanks!
~Michael
'92 Pearl White LS-L Touring SOLD
4.44 Swap, trans cooler, trans filter, trans temp gauge
Color-matched rear body and spoiler, X-drilled and slotted rotors, Axis pads, s/s lines
Raxles front axles
Old 01-12-2006, 11:32 AM
Dza's Avatar
Dza Dza is offline
#073 of 301
From what I have learned on here and from my mechanic, flushing the fluid in the tranny is not the best idea. It stirs up the settled crud (technical term) and could potentially damage the tranny.
Of course, people have done it and had 0 problems so YMMV
Dan M.
Barcelona Red '93 AE #073 of 301, 168k miles.
Old 01-12-2006, 12:18 PM
Flushing can be good or bad. How many miles on the tranny? Has it been flushed before?
I would use synthetic fluid as they can normally handle higher temperatures better.
Old 01-12-2006, 12:32 PM
n00b on demand's Avatar
Just drain and refill. If it is a high mileage tranny dont get it flushed.
Old 01-12-2006, 12:55 PM
Sold. :'-(
The trans was rebuilt 2 years ago and has much less than 10K on it.
It is getting warm (not bad enough for the light, but you can smell it) on long drives, and when warm, hesitates going into reverse.
From what I've read, this can be a clogged filter, or a clog elsewhere in the trans, and a flush may correct it.
Thoughts?
Raxles front axles
Old 01-12-2006, 01:01 PM
Do you know what was replaced with the rebuild? If it was flushed or cleaned with the rebuild then you should be safe to flush this tranny.
Old 01-12-2006, 04:06 PM
Thoughts?
Hi Michael, hesitating going into reverse, is from low line pressure. This can be from a faulty pump gasket, but as it has been rebuilt, it should have the modified one.
So I would drop the pan, to check that the ATF pick-up screen is clear. What is the condition of the ATF, does it look degraded, brown,smell burnt?
When they rebuilt the trans, did they check that the cooler in the radiator is clear.
Old 01-12-2006, 04:24 PM
Sold. :'-(
I have no idea, it was rebuilt before I bought it.
I have no choice but to go with the assumption that they didn't know what they were working on and rebuilt it with off the shelf parts and backwoods theology, just like it were a Buick or anything else.
I'll check the pickup screen, filter, fluid, etc, but how do I check the cooler in the radiator?
THANKS!
Raxles front axles
Old 01-12-2006, 05:12 PM
THANKS!
Pull the front under cover off, remove the two hoses that connect to the bottom of the radiator. I forget which is the in and out pipes, some will know. Blow air in the out connection, see that comes out the other connection (bits of lining?). Don't blow pressure in the in connector as it may cause it to block harder.
Old 01-12-2006, 06:41 PM
Sold. :'-(
Excellent!
Someone let me know which is the in and which is the out, please.
Raxles front axles
Old 01-12-2006, 10:37 PM
Excellent!
Looks like the left hand side is the inlet to the cooler. You can be sure, if you disconnect both, see which one the oil comes out of when you turn the motor over.
Old 01-12-2006, 10:48 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Wink
The IN line will be the one coming off the tranny filter to the cooler.
Old 01-13-2006, 09:31 AM
Sold. :'-(
Ehhhxcehhlehhhnnt.
Fluid/filter recommendations? I'm going shopping today or tomorrow.
THANKS!
Raxles front axles
Old 01-15-2006, 01:40 PM
STORMINORMAN STORMINORMAN is offline
Thumbs up Fluid, filter...
I use Chevron Dextron III when I can get it for $0.99/quart, Subaru's in line replacement filter kit gives you new lines, clips, etc., virtually anybody's (i.e. NAPA, etc.) transmission pan filter as far as I'm concerned.
Using the transmission itself to pump out 4-5 quarts at a time (as is described in previous DIY posts) after draining & cleaning the pan seems to avoid allmost all the risks associated with a machine "power flush". Remember that the cooler line in the radiator also has a screen that can plug: it is good to make sure that this line is flowing normally.
Good luck!
' 92 SVX @ 185K
' 91 420SEL @ 223K!
' 88 420SEL I. @ 178K (what a buy!)
' 87 F250 @ 180K
' 93 ZX-11D @ 29K
' 93 SC400 @ 93K
2001 Valkyrie Interstate @ 6.6K (Brynhild)
Y2K NightHawk 250 @ 1,500 miles
' 88 420SEL II. @ 208K
'85 F150 @ 135K
