Old 01-09-2006, 12:36 PM
baccura
WRX wheels and hubs
Ok I know the WRX has the 5 x100 wheels and SVX has 5 by 114.3 wheels but can you adapt the current Subaru Imprex hubs to the SVX what all is different?
Old 01-10-2006, 10:43 PM
WGJ WGJ is offline
Wrx Wheels
are a direct bolt on if new enough. Check the search function to see if you can find the appropriate thread.
WGJ
Old 01-11-2006, 09:32 AM
mbtoloczko's Avatar
sans SVX
WGJ
Only the 2005-2006 WRX STi has the same bolt pattern and offset as the SVX. No other Subaru cars have the same.
Mychailo
Visit my locker
Old 01-11-2006, 10:12 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
I know this is a HUGE stretch, but has anyone compared the front hub carriers to see if they will interchange allowing us to use OEM or aftermarket STi Brakes? I know that the strut mount, ball joint mount, tie rod mount or bearing mount are probably different, but I figure it is worth a shot.
SVX Hub Carrier Right: 28012PA000
SVX Hub Carrier Left: 28012PA010
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 01-11-2006, 10:14 AM
baccura
I am curious about all this as well can we use the newer axles hubs uprights on the SVX?
Old 01-11-2006, 11:03 AM
AppStateSVX's Avatar
AppStateSVX AppStateSVX is offline
Mountaineer
Send a message via AIM to AppStateSVX
i've also read somewhere, not sure where though unfortuneately that the STi has the same wheel bearings as the SVX. Can anyone confirm this?
1992 Midnight Black LS-L - Sold 3/3/06
1991 Toyota MR2 - Sold 11/27/07
1992 BMW 325i
- Tokicko Suspension
Old 01-11-2006, 12:43 PM
mbtoloczko's Avatar
sans SVX
The USDM WRX STi shares the same rear wheel bearing as the SVX. Not the front though.
Doug, the PN for the hub carriers on the STi are different than the SVX.
Mychailo
Visit my locker
Old 01-11-2006, 03:55 PM
mohrds's Avatar
Do you know if the splines on the front axles are different?
I wish I could get my hands on one to see just what it would take to port the parts over to the SVX.
1994 LSi (4/93)
2000 Ford Excursion
Old 01-11-2006, 04:47 PM
Mr. Pockets's Avatar
Moderator
The fact that the parts carry different numbers is almost worthless. The coolant temp sensor is the same on the SVX and second-gen Legacy - yet they use different part numbers and have different prices.
The only way to be sure is to physically compare the two parts. I would be very surprised if they were interchangeable.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
