The lower the # gear ratio, the more stress there is on the transmission. The WRX 5 speed has a 3.90 front differential that has a 1.1 step down to use a 3.54 rear differential
Tom |
A 4.444:1 axle ratio causes the least amount of stress on the tranny and engine because the low ratio means that the tranny/engine have a greater mechanical advantage when it comes to accelerating the vehicle. Higher ratios add more stress to the tranny/engine. The 4.444:1 ring & pinion is the weakest of the ring & pinion gears though because of the small number of teeth on the pinion gear.
Mychailo :: 2006 Silver Mitsubishi Evolution 9, E85, 34 psi peak, 425wtq/505whp DJ :: 1995 Laguna Blue SVX L AWD 5MT (sold) Visit my locker SVX Mods: ND iridium spark plugs, Impreza RS fpr, afr tuned to 13.2:1 using a custom MAF bypass, custom exhaust, WRX 5MT w/ STi RA 1st-4th gear & stock WRX 5th gear, Exedy 13 lb flywheel & Sport Clutch, STi Group N tranny & engine mounts, urethane spacers in rear subframe, rear diff mounts, and pitch stopper, SVX Sport Strut Springs (185f/150r), custom 19 mm rear swaybar, urethane swaybar mounts, Rota Torque 17x8", 225/45-17 Proxes 4 tires, Axxis Deluxe Plus organic brake pads. Last edited by mbtoloczko; 01-08-2006 at 02:05 PM. |
