Old 01-03-2006, 06:56 PM
Amazonparrot's Avatar
Amazonparrot Amazonparrot is offline
Now with Colder Air!
Send a message via AIM to Amazonparrot Send a message via MSN to Amazonparrot
How would you describe a dying axle?
SVXFiles has indicated to me that some symptoms that I described to him are partially indicative of a failing axle. That being said, without me listing those symptoms, what are some signs/sounds of a failing axle. Thanks much!
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD*
2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp).
Charlottesville, VA Represent! (voted #1 place in America to live!)
http://www.subaru-svx.net/photos/user.php?Amazonparrot
Old 01-03-2006, 06:58 PM
JeffN JeffN is offline
Front: clicking at creeping speeds on full lock in either direction.
Sold-Black 97: They're All We'll Drive-into the side of a Pathfinder that lost it's path!
2004 Stage 3 XT Forester-Soon for sale!
2007 Jag S-type, just 17k on it!
Past prides: 1992 black LsL new off the lot.
1992 pearlie for a few months.
Old 01-03-2006, 09:19 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
I just replaced one of mine and it sounded like a sharp clicking when I made sharp left turns and sometimes right ones too.
Old 01-03-2006, 10:39 PM
SAD !!
Old 01-04-2006, 05:20 PM
SAD !!
Very cute Earl The sound I am hearing is a distinct ringing that is only present at soft to moderate acceleration, and for the first second after letting off. The sound is not present at all if you take it out of gear, yet most present once in OD, (even moreso at higher speeds). I know its not bearings, but as i was saying, axle was suggested to me as a problem. Any ideas?
Old 01-04-2006, 05:53 PM
Have you thought maybe the front diff?
Old 01-04-2006, 05:54 PM
I've had it go out and be replaced before, so I'm familiar with the sound, and this is something different altogether. Thanks for the thought though!
Old 01-06-2006, 07:16 PM
Lemme just bump this to the top here....
