Old 01-01-2006, 10:24 AM
1320boy's Avatar
1320boy 1320boy is offline
Team ROUND 1
Send a message via Yahoo to 1320boy
My "Power" light flashes.......
As soon as i start my car its solid for 2 full seconds then it flashes rapidly for 5 seconds, plus my break light stays on even when my brake is down. Only after 10 min of driving it goes off.
Has anything like this happend to any one of you guy's
Old 01-01-2006, 10:37 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
The brake light works for both the emergency brake and the brake fluid. Check the brake fluid. Make sure the under part of the cap is not expanded.
Old 01-01-2006, 10:47 AM
Count the number of times the Power Light flashes and check the code.
The suggestion above about the brake fluid is correct. After only a few minutes, the fluid heats up and expands which turns the light off. Top it off and it will stay off.
Old 01-01-2006, 11:14 AM
1320boy's Avatar
Team ROUND 1
Ok the brake fluid i'll check but there's a code for the power light???
As a question out of curiosity whats it for???
Very
Old 01-01-2006, 11:35 AM
dannmarr's Avatar
I work for my SVX
I thought you read the CHECK ENGINE light for a code?
Old 01-01-2006, 01:16 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
If the power light flashes 16 times when you first start the car, doesn't that mean you have a transmission trouble code stored?
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 01-01-2006, 01:54 PM
You count the number of flashes and then check for the code. Yes, it gives you transmission codes.
Old 01-01-2006, 02:23 PM
So he goes here. http://www.svx-iw.com/
Click on SVXipedia, then click on "checking error codes", then click on "check transmission codes", then follow the directions on how to pull the code.
The flashing power light at start up is only telling you there is a trouble code stored in your TCU, you have to go through the frustration of pulling the actual code to find out whats wrong. It's a "turn off key, put in drive, then reverse, etc., style thing.
I have yet to make the combination work the first time on 2 separate SVX's. Might take a couple of attempts to get the code/codes to come up.
Robert
Old 01-01-2006, 07:08 PM
1320boy's Avatar
Team ROUND 1
So it might be my tranny?????
It was just replaced or you think they might have put in awrong code or something?????
Old 01-01-2006, 07:28 PM
dwd1985 dwd1985 is offline
Having a transmission code doesnt neccessarily mean that your transmission is about to go or anything, the codes could mean alot of things. I got a code for a duty solenoid A malfunction, and it just turned out to be the transmission resister that plugs in next to the battery, and was a cheap, easy, and quick fix. Just pull the code using the method in the SVXipedia, and look up what it is. As soon as you find out, do a search or post your finding in this forum, and someone here will tell you how to fix your problem. It could be somehting as simple as a sensor that needs replacing.
Old 01-02-2006, 12:50 PM
1320boy's Avatar
Team ROUND 1
Unfortunatly im an idiot with codes and stuff
All i know is when i start the car the "Power" indicator is on for 2 full seconds
then blinks rapidly for about 15-16 times?????
Any of you guy's know what that means
I'm stumped
Old 01-02-2006, 01:05 PM
The power light flashing 16 times means your Transmission Control Unit has stored a trouble code.
To retrieve the trouble code, check out the instructions in post#8.
Robert
