Old 01-01-2006, 01:56 PM
If you unplug them, you are ok. It is when they short out that you have problems.
Old 01-09-2006, 01:10 PM
spinn360's Avatar
spinn360 spinn360 is offline
DID you check all the coils?? Is the car running on all 6 cylinders>?
1989 Subaru XT6 130k
1992 Subaru SVX 120k
1993 Ford Probe 30mpg 213k
1989 Subaru XT6 150k
All good and running
Old 01-09-2006, 09:07 PM
Invisible avatar
You may want to PM SVXcess (John). I don't remember the exact symptoms he experienced with his '95, but it had an electrical problem that a number of mechanics could only scratch their heads about. The problem was finally traced to a feeder wire under or buried in the fusebox that appeared to be a factory defect. The wire appeared "crushed", & I believe the insulation finally deteriorated to the point of creating goofy problems. The fusebox had to be replaced, but the agony ceased.
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 01-09-2006, 10:35 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
The one under the hood? (are there two?)
Thanks I'll dig around there because even after my exhaust fix, the car still randomly sputters and stalls while stopped.
Brian
Old 01-09-2006, 10:57 PM
If it really only acts up while at a stop or idle it would seem to me like a vaccum leak or a leaky intake gasket. Are there any electrical happenings that would suggest otherwise??
Old 01-09-2006, 11:01 PM
Invisible avatar
[QUOTE=Ricochet]The one under the hood? (are there two?)
Yup...it's the only one that I'm familiar with.
Ron.
'01 Miata SE - 79K
Old 01-09-2006, 11:10 PM
There is another one behind the kick pannel too.
(I think)
Old 01-10-2006, 03:04 AM
Ricochet's Avatar
I brought some ham.
It only completely dies while I'm stopped, but hesitates sometimes while driving too.. It feels like a fuel cut or something.
Brian
Old 01-10-2006, 08:07 AM
Mr. Pockets's Avatar
Moderator
Originally Posted by Ricochet
Yes I had the alternator and battery both checked.. both are perfectly fine.
I haven't finished reading this thread yet, but I wanted to chime in with my experience.
I don't trust auto parts shops when it comes to 'testing' alternators and batteries. I've had them tell me an alternator was perfectly fine, then I've gone home and replaced it with another and had the problems solved.
Those shops only 'test' an alternator for 4-5 seconds, so they'll easily miss an intermittent problem or one caused by heat.
My only point is that I wouldn't implicitly trust an alternator just because a shop 'tested' it. I wouldn't rule it out.
That being said, I do want to agree with both Nik and Todd on their different points. Nik reminded you that the car is 14 years old. It's new to you, but it's not new in the least. It's going to need care. And I also think Todd had a good suggestion in the vacuum lines. They're all over the place, they're of different sizes and some are very hard to get to.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 01-10-2006, 08:36 AM
n00b on demand's Avatar
Yeah agreed. I always seem to think im driving a new car sometimes so when something goes wrong i get extra pissed off. But then i think about it and im like this is a 13 year old car so things are going to break and go wrong. And thats exactly why im taking care of all the routine maintanence before i start to auto-x it
