Old 12-11-2005, 02:04 PM
bcpianoman bcpianoman is offline
I smell gas
When I start the car cold in the morning there's a gas smell that lingers until the car warms up to normal operating temperature. After that the smell goes away.
i've looked under the hood and on the ground but there is no visual sign of any leak.
The car runs a little rough too when cold but not all that bad.
Any ideas?
Old 12-11-2005, 02:17 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Mine had the same problem. Sounds strange, but I had weak O2 sensors, and it was making the car run extremely rich. I smelt gas.
I replaced both O2 sensors, and the car started running smooth, my gas mileage went through the roof, and I no longer smell gas.
I'm not saying you have the same problem, but take a look at your last couple of emissions tests and see if they are getting worse.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 12-11-2005, 09:07 PM
intelisevil's Avatar
<<<Alcyone
Emissions Tests? What are those for?
I live about two miles beyond the border for emissions testing in my area. I wasn't even aware of it when I bought my home, really!
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 12-12-2005, 06:01 AM
dcarrb dcarrb is offline
I got to smelling raw gas in mine upon startup a few weeks ago and found that the clamp on the engine side of the fuel filter had loosened just enough to allow gas to seep past, but only with the system pressurized. Hose is good; all I did was re-seat it and the clamp.
dcb
Old 12-12-2005, 03:58 PM
It could be possible you have a leaky injector.
Old 12-12-2005, 04:46 PM
Or,
a loose inlet manifold.
