Old 12-05-2005, 12:29 PM
rabbitman
front suspension clunking
My 1994 svx si started making a clunking sound when driving over any bumps, the dealer said that it was the front struts or the upper strut bushings...I ordered new complete front struts and new upper strut bushing and replaced them myself....guess what....the front end still clunks...and the dealer doesn't know what it is everything is tight and secure....does anyone have any other ideas as to what the real problem is......thanks..........
Old 12-05-2005, 01:46 PM
n00b on demand's Avatar
You radio isn't turned up loud enough!
Old 12-05-2005, 01:57 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Did you check the swaybar bushings and the connecting rod?
I found that my connecting rod was so loose it would bounce all over the place.
Once I tightened it the noise went away.... and it was originally a very bad clunking...
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-06-2005, 06:25 PM
JD da ricer
I have a similar problem where a couple of times I would hear that noise when I am backing up while steering, like when I pull out of a parking space. I put my car up on a lift to check the suspension and it all looked good. So I torqued down the bolts and found that one of the front lower control arms had a loose bolt. I don't know if that fixed it but I haven't heard that clunking for a few days.
Old 12-06-2005, 11:23 PM
JD da ricer
scratch that, just got the steering clunk tonight. Need suggestions.
Old 12-06-2005, 11:27 PM
SubaSteevo's Avatar
No longer blue member
Had the exact same problem, now also fixed
-Steve
01' MSM Lexus IS300
Old 12-07-2005, 12:13 AM
for those who don't know what they are talking about... The sway bar ends bolt up to the strut housing on the front struts... These bolts are more than likely loose... Tighten them to spec and you are good to go
