Old 11-30-2005, 06:46 PM
Ovidiu STAN Ovidiu STAN is offline
Front seals replacement
I have a continuous leak (1 drop overnight) of oil in front of the car. I assume that is one of the 3 seals that is damaged. BTW. The car has 90K.
Can I replace them only by removing the harmonic balancer and the timming belt sprockets?
Any previous experience is appreciated.
Thanks
Old 11-30-2005, 06:52 PM
mbtoloczko's Avatar
sans SVX
Are you sure its not the PS pump reservior or high pressure outlet seal? When those leak, it can run down the front of the engine.
Mychailo
Visit my locker
Old 12-01-2005, 09:15 AM
The power steering is dry as a Martini
Old 12-01-2005, 02:35 PM
immortal_suby's Avatar
Thread Killah
Thanks
Follow the timing belt change how to and only add in the steps of removing the front main crank sprocket and the cam sprockets.
Pretty easy to do if you can buy or make the right tool to hold the cam sprockets in place to break the bolt free.
http://www.ryanmacdonald.com/car/howto/
Locker Link
2015 BRZ Limited 6MT
Old 12-01-2005, 05:13 PM
mbtoloczko's Avatar
sans SVX
Do you mean that there is no fluid on the exterior of the PS pump and hose, or do yo mean that there is no fluid in the reservior?
Mychailo
Visit my locker
Old 12-01-2005, 07:05 PM
alia176 alia176 is offline
In case you haven't checked this already, take a gander at the valve covers to rule them out.
Ali
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
