Old 11-26-2005, 02:53 PM
96redsvx 96redsvx is offline
Send a message via AIM to 96redsvx
Troublesome Trany
another day another transmision problem it started slipping about a week ago and i was just about to adjust the brake bands but needed a smaller wrench and on the way to get it the trany felt like it just fell into nutrual but it was in D so i put it in 3 and no luck but 1 and 2 grab and hold. except when starting from a dead stop under light acceleration with the shifter in D it will Start in 1st then shift to 2nd stay there for a couple seconds then it feels like nutruel the revs go up to somewhere around 4000 and its like its back in first if i dont floor board it from there it wont wind out into second then i max 2nd then it feels like it just lets loose.
But if i put the shifter in second it doesnt slip between 1st and 2nd but still no 3rd or 4th.
I checked for codes theres no power light and no debries in trany fluid smell alitle funk but not terible i suspect the high clucth but iam not positive.
Help ME!!!!!!!!!!
Old 11-26-2005, 03:47 PM
Help ME!!!!!!!!!!
Yes it does look like the high clutch is slipping. Have you removed the trans pan to clean the oil pick-up screen.
