Old 11-23-2005, 01:19 AM
kuroneko_sama's Avatar
kuroneko_sama kuroneko_sama is offline
aka sir_romeo
Send a message via MSN to kuroneko_sama Send a message via Yahoo to kuroneko_sama
at what point would a second battery be needed
im considering running 4 200w amplifiers (one audiobahn A2002T for both my back speakers, one audiobahn A2002T for both my front speakers and tweeters, and two basslinks)
would i need a second battery?
I Leave late and STILL manage to arrive early
Car #26..'97 SVX Silver (120k and climbing)
previous SVXi:
Car #24..'94 SVX Ebony 216k (sold)
car #18..'97 SVX LSI "Ebby" Pearl 175k (sold)
car #19..'97 SVX LSI Brilliant Red 103k (sold)
car #14..'92 SVX Claret LS-L Touring (sold)
car #13..'94 SVX Laguna Blue LS (sold)
Old 11-23-2005, 05:26 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
If you have the original alternator (95 amps) and your battery is about 12-14 volts, you have about 1200 watts to play with (I x E = P ). Just add up all your accessories to see if that’s enough. Also keep in mind, the speakers rating is it's peak. You probably won't go that high. Make sure your amp can also handle that output.
Old 11-23-2005, 08:53 AM
kuoh kuoh is offline
That 95 amps is the peak rating, it won't be putting that much out most of the time and would probably burn up in no time if it was required to. 4 200W RMS amps sounds a little excessive, unless you plan to enter a sound off competition, then they're probably a little on the puny side.
My SVX is on its second replacement alternator and I've only had about 300-400 watts RMS total between the various amps and no additional lights or other electrical loads. With the headlights on at stoplights, my system voltage hovers at around 11.5-12.5 volts, worse if the AC kicks in. Once on the move though, it rises to 12.7-13.7 volts. My suggestion would be that if you plan to cruise around in the city with 4 200W amps, install a second battery and have a spare alternator ready at home.
KuoH
Old 11-23-2005, 09:44 AM
drivemusicnow's Avatar
Poor College Racer
I run about 1900 watts RMS in my SVX. I'd suggest getting the Napa replacement alternator when you kill yours as its a 110 amp alt I believe. Also, a second battery only helps you when they are both fully charged. If you're constantly pulling current from them at a faster rate than it is being replaced, the only difference between one battery is that it will take slightly longer to kill both..
I'm sorting out a new electrical issue. I have warranties on both the battery and the alt so I need to figure out which one is faulty and which one is getting replaced for free
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 11-23-2005, 10:59 AM
I've run 1380w (max) with one battery.
Old 11-24-2005, 12:25 AM
aka sir_romeo
well it just happens to be what i have, i dont plan on doing competition or anything liek that , i jsut want good clarity and decent sound
previous SVXi:
Old 11-24-2005, 08:24 AM
alia176 alia176 is offline
Instead of a second battery, purchase a high quality primary battery that has lots of AH. Check out the Odyssey batteries. They're millitary grade batteries, smaller in size, expensive and high quality! You can even get two small 12 volts that'll fit in the same tray!
Good luck.
Ali
ps that reminds me, I need to invest in hearing aid companies
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 11-24-2005, 08:35 AM
KCROGUEDOG
i had a 1200 watt alpine v12 in my maxima pushing 2 400w eclipse and i had no problems with a bass cap. tiny power pulling down battery. i could rattle a full two liter off the dash it hit so hard. before that i had a 800 watt alpine v12 in my fiero with no cap pushing 1 pheniox gold x max. i had a little head lite diming.
Old 11-25-2005, 01:28 AM
aka sir_romeo
the issue is 4, 200w amps are different than 1, 1200 w amp i am interested in the concept of the millitary batteries, or i wonder why they dont make batterys that fit in odd places, like a donut shaped battery for the inside of your spare tire or something
previous SVXi:
