Old 11-16-2005, 08:45 AM
Htownsvx Htownsvx is offline
Send a message via Yahoo to Htownsvx
motor oil
my svx is a 92 with 105,238 mile,
im getting the oil changed here soon and im not sure what weight oil to get
it has moble one supersin 5w30 int it now. should i got higher i don live in houston tx and it warm or hot most of the time?
01 subaru legacy 5sp
97 J-spec kl-ze 5sp ford probe
the best of them all the 92 lsl svx amost 100,000 mile
Old 11-16-2005, 09:37 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Owner's manual says either 10W30 or 5W30 would be fine. 10W30 is recommended for the hot months while the thinner 5W30 is recommended for the cold.
-Chike
2006 Steel Gray WRX TR (sold)
Old 11-16-2005, 03:51 PM
mbtoloczko's Avatar
sans SVX
From freezing to 95-ish, 10W-30 is good. In hotter temperatures, some recommend 10W-40, but I've heard that the thickening agent used in wide weight range oils is more prone to burning and leaving deposits on rings.
Mychailo
Visit my locker
Old 11-16-2005, 04:29 PM
This is according to the oil used. For example the Castrol 10W-60 supersynthetic has an additional ingredient for that kind of issue. I used it for long time, it was great but now i was forced to switch to Total 10W-50 (French oil). It is still the best i can find over here.
Old 11-16-2005, 10:27 PM
Bobb Bobb is offline
Oil
Hi H, If you go to www.mobil1.com your can put in you data and they will make a recommendation of which oil you should use. Take care, BOBB
Old 11-17-2005, 11:13 PM
WGJ WGJ is offline
Amsoil
I highly recommend AMSOIL.
WGJ
Old 11-18-2005, 09:47 PM
Manarius's Avatar
Manarius Manarius is offline
I run 20-50w in my car..it's Dino Oil too
-Jason
-Obi Wan Kenobi
Old 11-20-2005, 06:57 PM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
Mobil 1 5W30, year round.
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
