Old 11-06-2005, 01:41 PM
intelisevil's Avatar
<<<Alcyone
Intermittent Rear Wiper
Over the last couple of weeks, my rear wiper has only worked intermittently.
Last night as I was heading home from work I tried to use it and I saw a slight movement but nothing more. One more try, a little less movement. It's trying to work. I got out of the car to see if I could 'free it up'.
Well, I'm happy to say it's fixed!!! At least until the next time I open the trunk and it gets caught under the edge of the trunk lid . . .
To really fix it I need to adjust it's parked position. Is it mounted on a splined shaft or do I just need to loosen a nut, adjust and retighten?
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 11-06-2005, 01:54 PM
It is splined. Good luck.
Old 11-06-2005, 02:21 PM
Manarius's Avatar
Manarius Manarius is offline
That's interesting. I know the front wipers on my car are not splined. You'd think that since they're the ones people use more often that they would be splined...
-Jason
-Obi Wan Kenobi
Old 11-06-2005, 11:50 PM
berger's Avatar
berger berger is offline
Send a message via ICQ to berger
my rear wipers were loose a few months ago, it ended up wiping the boot lid, i must say, it was rather clean, ina semi cricle kinda shape, jsut tightened the nut and it was fine again
