Old 11-05-2005, 10:47 PM
davew833 davew833 is offline
It Can Be Done! (Head Removal)
In my locker is a picture (it's the only one in there) of my now-headless '92 Pearl. You'll notice that the engine is STILL IN THE CAR. It took 10-12 hours of work at a leisurely pace to get the heads off, and after getting the the spark plugs/coil packs and valve covers off there was plenty of space on the sides to remove the cams (required) and finally unbolt the heads. Now the trick will be getting it all back together with new head gaskets to cure my overheating and oil in the coolant woes.headless engine
Old 11-05-2005, 11:03 PM
Impressive.
Old 11-06-2005, 12:15 AM
drivemusicnow's Avatar
Poor College Racer
why were you so desperate to keep the motor in the car? I don't know if it would have taken less time, but I would have pulled (or dropped... never done an SVX motor) that thing before I tried that.
Nice work though.
Just wondering, do you have the tools to take precise measurements?? like... thousandths of an inch? (or equiv)
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 11-06-2005, 12:18 AM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Wow.... I got tired, and my knuckles started bleeding by just "looking" at that picture. I'm going to go take a nap.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 11-06-2005, 07:38 AM
You are right Phil, scary picture. "parental guidance for SVX owners"
Old 11-06-2005, 08:55 AM
mbtoloczko's Avatar
sans SVX
Cool. Not much left of the engine in the car. :-) Were you able to see where the head gasket had failed?
Mychailo
Visit my locker
Old 11-06-2005, 09:07 AM
kuoh kuoh is offline
Doesn't removing the engine involve disconnecting a lot more hoses, wires, and tranny? For a home mechanic on a budget, this may be a viable option. It sounds like one may even be able to accomplish the gasket change over a weekend.
KuoH
Old 11-06-2005, 09:29 AM
I think I need a drink!
Old 11-06-2005, 09:36 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Removal?
Actually from where you are with the engine that is not that much more to remove and it would have been easier provided you have an engine hoist.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 11-06-2005, 12:27 PM
immortal_suby's Avatar
Thread Killah
Yeah, pulling an engine ain't that bad if you have a cherry picker but good job on getting the heads off with it in there. Amazing. Post a picture of your knuckles now - I bet they are bloody!
Locker Link
2015 BRZ Limited 6MT
Old 11-06-2005, 12:57 PM
lhopp77's Avatar
Now and/or Later!!
Yeah, if they ain't already skinned they probably will be by the time you get it back together.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 11-06-2005, 01:38 PM
I wonder how he was even able to type and post this thread...
J/K
Old 11-06-2005, 02:29 PM
nice work... Like the others... I would have pulled the motor. I am thinking of doing the same thing though...Just not taking the heads off...
Old 11-06-2005, 02:46 PM
J/K
That made me laugh out loud.
Robert
Old 11-07-2005, 08:58 AM
Re: Head Removal
Like kuoh said, I was looking for a "a viable option for the home mechanic on a budget". The shops I talked to about doing it quoted me $1400- $2000 labor ALONE to do the job. I believe an ambitious person could do the whole job over a weekend- minus the machine work, of course. I've pulled engines before, but last time I rented an engine hoist it was $30 a day and that was 5 years ago. I didn't want to spend the money this time if I didn't have to. I also couldn't believe what's been stated here periodically and at some repair shops I've talked to- that Subaru would build an engine that you couldn't remove the heads from without pulling the engine.
The disturbing thing about it all is that a quick inspection of the head gaskets didn't reveal any obvious failure points. Still, the car overheats, I've got oil in my coolant, and the coolant is disappearing (out the exhaust). What else could it be? A cracked block? In that case I'll be removing the rest of the engine anyway-
Just call me Don Quixote!
PS: My mother is typing this for me because of my bloody knuckles.
