Old 11-04-2005, 04:52 PM
madj80's Avatar
madj80 madj80 is offline
Send a message via Yahoo to madj80
CEL Error Code 23
Has anyone ever has this error code?
On svx-iw.com is reads "Abnormal voltage from air flow sensor." Is it talking about the MAF? Should I try cleaning it first before replacing it?
92 SVX LS-L Pearl (Sold 08/06)
92 SVX LS-L Liquid Silver (Sold 08/06)
Old 11-04-2005, 05:23 PM
You can try that. Some people have found theirs in need of soldering. See if you can find one in working condition to confirm yours is bad.
Old 11-04-2005, 09:39 PM
thundering02's Avatar
Giong back to the beaters...
http://www.subaru-svx.net/forum/showthread.php?t=29184 Thats the trhead that I'm currently working in....
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 11-04-2005, 09:46 PM
madj80's Avatar
Did cleaning it with vinegar help? I am going to try CRC electronics cleaner tomorrow evening. I will let you know what happens.
Old 11-05-2005, 10:07 AM
Nope...............
Old 11-05-2005, 07:00 PM
madj80's Avatar
I sprayer the MAF and connecting wiring harness with the CRC cleaner this morining. It was very dirty as well as the air filter which I changed. The car did not stall out all day. I did not have a chance to clear the error code and the temp today was only 50 degrees, so I am not sure if it worked officially or not.
Old 11-05-2005, 07:50 PM
Where did you pick it up? one last shot for mine. (the CRC that is)
Old 11-06-2005, 10:17 AM
madj80's Avatar
They had it a my local auto parts store (Checkers) for about $8. Make sure you let it dry, because it is highly flammable.
Old 11-10-2005, 08:25 PM
madj80's Avatar
Thumbs up
This evening I changed Knock Sensor #1 on my SVX. Took about 2 hours, since I removed the alternator and reset the error code. So far so good. I guess by cleaning the MAF with CRC cleaner the code 23 error was fixed as well. BTW: Well worth the $74 from Subaru for a new knock sensor.
Old 11-10-2005, 10:18 PM
Yeah the CRC did jack for mine unless you count that I now know that it has colors inside.... otherwise I picked one out of a junkyard from I think a legacy and it about 95% right but for $30 instead of $300 I wasn't going to say no to a chance
Old 11-11-2005, 06:14 PM
madj80's Avatar
Angry
Damn it's back. CODE 23 F****CK! Guess it's time for a new MAF? Or maybe not?
I have a god awfull whistle noise comming from the throttle body area (maybe a leak). Would that cause the MAF to malfunction? My thought is probably not since it is after the MAF on the intake.
Hey Thundering02, did your replacement MAF work?
Old 11-11-2005, 06:19 PM
Yes it would. You've got it backwards: any air leak before the MAF is fine. Leaks after the MAF allow unmetered air to enter the engine and that is bad if not controlled.
Old 11-11-2005, 06:41 PM
madj80's Avatar
What would be the best way to test for a leak? Carb cleaner on the hoses maybe? Vacuum line tester?
Old 11-14-2005, 09:53 AM
If the MAF is generating an error it's an electrical problem. It can't detect if there's an air leak. Either there's no signal or a signal that's out of acceptable range.
