Old 11-01-2005, 05:41 PM
sperry's Avatar
sperry sperry is offline
$1 is just $1, but $2 = nachos
Clunk under braking
I've got a bit of a clunk under braking.
When I 1st apply the brakes and the car pitches I can hear something from the driver's side firewall clunk. It's been doing it for maybe two months or so... but it's recently started getting worse.
If I don't brake hard, it doesn't happen. If I brake really hard, it clunks extra loud, then the next time I accelerate I hear it "un-clunk". I can't seem to get it to happen with the car stopped and jumping on the door sill or anything... only seems to happen while driving, but it's easily repeatable. Also, I can kinda "feel" the clunk through the pedals.
I'm thinking my LF strut is blown, and it's binding and unsticking when the car pitches forward... but it could be the engine or tranny mounts, perhaps.
Is anyone familiar with this noise, before I go and start poking around every little nook and cranny under the car?
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty
Old 11-01-2005, 05:48 PM
Can you reproduce the sound by "bouncing" the car?
Old 11-01-2005, 07:20 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
If you have not done that yet, you can not call yourself a SVX owner yet.
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 11-01-2005, 08:16 PM
sperry's Avatar
Nope.... only with the car rolling.
Old 11-01-2005, 08:22 PM
mbtoloczko's Avatar
sans SVX
Does it clunk going over bumps (without any braking)?
Mychailo
Visit my locker
Old 11-01-2005, 08:29 PM
sperry's Avatar
Well, I have gotten under there and looked around. Which prompted me to have to replace a busted axle... So, I try to avoid getting under there, as it tends to cost me money.
Old 11-01-2005, 08:30 PM
sperry's Avatar
Good question... I don't think I've really noticed it, but I can't tell for sure, since I haven't gone looking for bumps. I think it's the actual pitching of the car that causes it, not just the compression of the strut... which it making me think "engine mount".
Old 11-01-2005, 08:42 PM
AvPPoW AvPPoW is offline
rev the car in neutral and let go, if it does it it's the motor mount
Old 11-02-2005, 02:36 AM
Clucking caliper.
Loose caliper bolts,or worn caliper slide pins.
Old 11-02-2005, 11:35 AM
sperry's Avatar
That would surprise me, since the clunk doesn't happen every time I brake, only when I brake hard enough. Also, I can distinctly feel it in the firewall, which makes me think it the strut translating through the top mount.
Old 11-02-2005, 01:48 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Not sure if the brake booster would cause a sound like that? Do you feel anything in the pedal when the noise happens?
1995 Subaru Svx L / AWD
Old 11-02-2005, 10:38 PM
sperry's Avatar
It could be. I can feel the clunk in the pedal, but it certainly isn't directly against the pedal. However, if the booster were loose, I'd expect to feel it every time I hit the pedal (and even when parked) rather than only when it's under a significant amount of braking.
