Old 10-30-2005, 07:59 PM
joeaxial joeaxial is offline
Whats the black plastic box bolted under intake?
I started replacing all the vaccum lines today and broke one of the ports off the black plastic box bolted to the bottom side of the intake. What is this thing? does anyone have a part number?
Thanks in advance,
Steve
1992 SVX lsl - >111K, pearl, 4.44 gears, ECUtune stage 1
2005 Outback XT wagon - i love that turbo!!!!
2004 Dodge Ram 1500 Hemi
Old 10-30-2005, 08:25 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thanks in advance,
Steve
Need more info or a pic.
Is this 'black box' in the fender? If so, then you're talking about the intake resonator. If not, are you talking about something attached to the air filter intake pipe? Are you even referring to the MAF (that's a black box) which sits between the air filter box and intake tube?
-Chike ?????
2006 Steel Gray WRX TR (sold)
Old 10-30-2005, 08:53 PM
I think you are referring to the air control valve, located under the throttle body. See part #2 HERE
Old 10-31-2005, 06:19 AM
What I'm looking at is attached to the under side of the intake manifold. I removed the manifold to replace the brittle vaccum and pvc air lines. There are several solenoids under the intake, but this part has only two vaccum lines attached to it and is located near the middle of the front of the manifold on the bottom side. I think its about 3" wide by 2" deep by 3-1/2" long constructed of black plastic. I'll try to post some pictures tonight
Steve
Old 10-31-2005, 09:14 AM
I looked at the part again. I think its just a vaccum resevoir. Any thoughts, part numbers???
Old 10-31-2005, 10:08 AM
RedHotSVX RedHotSVX is offline
gettin there....
Send a message via AIM to RedHotSVX Send a message via MSN to RedHotSVX Send a message via Yahoo to RedHotSVX
The service manual just refers to it as a Vacuum tank,also a Vc tank,one of the lines has a 1 way valve on it,the other line goes to the induction control solenoid valve.As far as Part #,I do not have that info....sorry
Mike....
8/96......Vin 100109
1997 LSI,18 inch Axis wheel(summer),16 inch ALT wheels(winter),Trans temp/Volt gauges,Iridium plug's, Autotechnica intake,silverstar high/low and fogs,polyurethane sway bar bushing's front and rear,Smallcar shift kit,Stebro exhaust finally..SWEET!!
Motorsports drilled/slotted rotor's front and rear with ceramic pads and SS brake lines.
1997 SUS Legacy,finally got the engine in after a year!!
www.myspace.com/devilhornz
Old 10-31-2005, 03:08 PM
oab_au oab_au is online now
IRIS vacuum tank.
Yes it holds vacuum to work the IRIS butterfly valve. You could glue the pipe back on the tank, with an epoxy glue, pass a drill bit through the pipe, to remove any glue in there.
Old 11-02-2005, 05:31 PM
immortal_suby's Avatar
Thread Killah
This thing?
I responded in your other thread.
If the epoxy trick doesn't work out I have a spare I can send you.
Locker Link
2015 BRZ Limited 6MT
Old 11-03-2005, 06:22 AM
Thats the part
I repaired it by cutting off the "ears" around the broken nipple and then used a 1/8" NPT tap to cut threads into the plastic. I found a 1/8" hose barb with 1/8" NPT at the hardware store and threaded it in, sealing the threads with silicon sealant. I'll post pictures of this and my replacement of the IRIS control diaphragm (I'm modifying the Vacuum secondary control diaphragm from an old Holley 4bbl carb to fit in place of the IRIS diaphragm) when they are both done.
Steve
Originally Posted by immortal_suby
This thing?
