It looks like they took the hood off of a Mustang and the gauges from an Audi.
Oh wait, isn't Subaru barrowing a certain GM platform for an up coming vehicle, only after in what some people may consider whoring out the WRX one? Nobody's perfect. If it's not Subaru, it's crap. |
I like the overall look....not too fond of the headlights though. I feel like I am at a fancy restaurant looking at the 8 forks on the side of my plate wondering which one to use next.
I agree with the pricing though, for that kind of money I would have an STi. |
i like the Mazdaspeed6, but, like the S60R, all the power is needed to move its big fat arse. they are kinda heavy.
CURB WEIGHT: 3630 pounds (est.) 0 TO 62 MPH: 6.6 seconds (mfr.) 6.6 sec, IMHO just isn't really that fast, considering the Forester XT will do 5.3. for 30 large, i'll take an STi, too. (or, of course, the GTP or WS6! )
Alan 1987 928 S4 (Black) SOLD! 1997 SVX LSi (Ebony) SOLD! 2005 Legacy GT (Silver) [Cobb Stg 2+] SOLD! 1987 928 S4 (Black) SOLD! 2005 Forester XT Premium (Crystal Gray Metallic) SOLD! 2008 Lancer Evolution X MR (Apex Silver) [Cobb Stg 1+] 2015 Outlander Sport 2.4GT AWD (Mercury Gray) 2013 G37xS (Obsidian Black) |
MazdaSpeed 6 Specs
MAZDASPEED6
Engine type 2.3L DOHC 16-valve Inline-4 with turbo Horsepower, SAE net 274 @ 5500 rpm Torque, SAE net 280 @ 3000 rpm Redline 6700 rpm Displacement (cubic inches) 137.9 Bore x stroke (inches) 3.44 x 3.70 Compression ratio 9.5:1 Fuel system Direct injection Recommended fuel Premium unleaded Minimum fuel requirement 91 octane (98 RON) Valvetrain 4 valves per cylinder, mechanical lifters Engine block Aluminum alloy Cylinder heads Aluminum alloy Emission control 3-way catalytic converter Ignition system Full transistor breakerless electronic Alternator 12V-110AH Battery 55D23L Starter 12V-1.4kw Type All-Wheel Drive (AWD) Transmissions 6-speed manual Clutch type Single dry plate with diaphragm spring Transmission ratios (:1) 1st 3.538 2nd 2.238 3rd 1.535 4th 1.171 5th 1.085 6th 0.853 Reverse 3.831 Final Drive 1st - 4th 3.611 5th, 6th, Rev. 3.095 Body type 5-passenger, monocoque unit 4-door sedan Front suspension Independent, high-mount double wishbones, coil springs, and stabilizer bar Rear suspension Independent, E-type multi-link, coil springs, and stabilizer bar Shock absorbers Front Cylindrical, double-acting, twin tube Rear Cylindrical, double-acting, mono tube Steering type Rack-and-pinion Power assist Engine-rpm sensitive; variable power-assist Overall steering ratio 16.1:1 Steering wheel turns-to-Lock 2.6 Turning circle, curb-to-curb (feet) 36.8 Braking system Power assist; 4-wheel, 4-sensor, 3-channel Anti-Lock Brake System with Electronic Brakeforce Distribution Brake discs Front Ventilated discs (12.6 x 1.0 inches) Rear Solid discs (12.4 x 0.4 inches) Parking brake Mechanical, hand-operated on rear wheels Tires P215/45R18 93Y summer radials Tire inflation pressure (front/rear) 37.7 psi Wheels 7.0JJ x 18 Temporary spare tire T145/70D17 Temporary spare wheel 17 x 4T EPA Mileage (City/Highway) 20/26 Crankcase (U.S. quarts) 6.8 Engine coolant (U.S. quarts) 8.5 Fuel tank capacity (gallons) 15.9 EPA Passenger Volume (cubic feet) 96.1 EPA Cargo Volume 33.7 (cubic feet) Seats folded 60.5 EPA Total Volume (cubic feet) 131.7 EPA Vehicle Size Category Compact car Wheelbase 105.3 Track: (front & rear) 60.6 Length 186.8 Width 70.1 Height 56.3 Minimum ground clearance, laden 4.86 Weight distribution, % front:rear 60:40 Curb weight (Federal spec, lbs.) 3589 GVWR (lbs.) Total 4552 Front 2449 Rear 2103
You of all people should know that the mfr's estimates mean nothing. Porsche is also famous for under-rating their cars performance potential. With that much power in a 3600lb vehicle, sub 6 sec 0-60 times will be the very achievable (maybe even mid 5's). Besides, something tells me the Hp rating may be a bit low - with a 9.5:1 compression ratio and 15.6 psi of boost - I bet the car is making closer to 300hp at the crank. -Chike
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 01-06-2005 at 08:02 PM. |
Re: MazdaSpeed 6 Specs
I am the complete opposite of you in this area...I think the red looks awesome, and the indigo is too 1980's Tron-like. If you want Indiglo get a Timex. Plus, every Fast & F***ing Stupid wannabe has indigo guages. Though just like you, I would take a G35 coupe over any of the above mentioned cars. Even the GTP. Quote:
Ford's parts on any car other than a Ford is unfortunate. They need to worry about making decent cars under their own badge...before screwing up other companies' offerings as well. One of the biggest things I have against the 6 is that stupid Duratec V6. I do agree with one part in your statement though, the general population of this site seems to believe that Subaru is the only company that can make a worthwhile car. It's is a weird place, this "SVX Network". The rules of the regular world don't seem to apply here. It's one thing to love a particular car (I do) but quite another to hate every other car out there. That's going a bit far. |
Ford has a turbo AWD taurus?
-Chike P.S. And despite what some people on here think, 27.9K for a 280+hp awd sedan is a darn good deal. The Legacy 2.5GT is in the same price range and has 30hp less. The Infiniti is nice, but a bit too refined for my tastes - this is the same reason why I'm leaning away from the Volvo S60R.
-Chike
#28
Ok I feel that I must clarify. I am speaking only of the Mazda 6s. I do not have any experience with the Mazdaspeed version. I am not comparing it to other cars...only the 6s. The automatic version of the 6s that mandi and I priced was $28,650. So I get the feeling that they may be understating the price for the Mazdaspeed car...if not, then there's virtually no reason to not get the mazdaspeed version over the 6s.
#29
-Steve Member #895(the member formerly known as BurgundyBeast) 01' MSM Lexus IS300 |
#30
B9 (Scrambler) is the hybrid coupe. By replacement he means next expectant FHI flagship.
