Old 12-20-2004, 11:01 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
some wrx hp numbers o/t
the wrx dynoed in at 320 hp @ the flywheel @ 16 psi "low boost "and pump gas
we are hoping to push over 400 hp at full boost 24 psi on c16 with the FMIC 850cc injectors and a cluch that can hold
i can see up wards of 500 hp with some good tuning and some internal engine work done,i.e version 7 heads and reinforced pistons and rods
7,000 rpm is just not enough rpm on these cars..
any svxers in the fl area is more then welcome to take it out for a spin =>
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 12-20-2004, 12:17 PM
Royal Tiger's Avatar
Certified Porschephile
Sounds good. Have you seen any numbers on the capabilities of the EJ20 vs the EJ25 in the STi? I would think the STi should be able to get into the 400's fairly easy since it's at 300 stock. You still using your originaly motor? I have seen ads for JDM EJ20's that were used in the older STi's and RA's that were 276hp+. Good luck!!!!
Old 12-20-2004, 12:46 PM
yes pa the older sti version motors are the best to get even the 2.0 sti verses the US 2.5 liter is better.
its varly easy to get 350 hp out of sti, but they are limited to what the stock turbo puts out,
there are many things that actually hender really high hp sti's the drive by wire is one,, doesnt do much but cause more head aches, also the cams wich are electronicaly controled, not sure what the call them,, same as the vtec concept they also cause issues.. also being a whole new engine 2.5 liters parts are hard to come bye in the after market world
i think versions 7 and 8 are the best year to get they shimless buckets. and capable of reving to 8,500 rpms wich im planing on using those heads,,
also the standard wrx internals are prety weak they use steal rods not forged also no stainless teeel valves. and feruim or whatever its called ,,valves
basicaly like always the US gets screwed on the good stuff.
Old 12-20-2004, 03:35 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Awesome dyno numbers Solar! With a new clutch you should be running mid 12 in your current state of tune.
-Chike
2006 Steel Gray WRX TR (sold)
Old 12-20-2004, 04:02 PM
Re: some wrx hp numbers o/t
Originally posted by solarsvx
snip>
Was the engine dynoed on an engine dyno, or is the 'flywheel HP'a guesstament from wheel HP.?
Old 12-20-2004, 04:07 PM
u loose around 18-20% going to the wheels around 8 % for FWD and 12 % to RWD cars thes are all estimates, each car varies,
Old 12-20-2004, 04:25 PM
Thanks, what was the HP and torque at the wheels,and at what rpms was it. Inquiring minds and all that. got to add it to the info bank.
Old 12-20-2004, 04:31 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
Ya i was gonna say, i have a friend wit ha pe1820 and put down 326 AWHP, thats completely built.
So you put down in the 250 range? sweet!
phil
~Phil
Old 12-20-2004, 04:40 PM
phil
Excuse my Ausse ignorance Phil, but what is a ' ha pe 1820'?
Old 12-20-2004, 05:22 PM
Phast SVX's Avatar
well youll have to exuse my bad typing skills
first part is suppose to be "With a" lol
and about the PE1820, its a big expensive turbo:
http://gruppe-s.com/Subaru/subeng.htm
Power enterprise 1820 ... it should speak for itself after this He has duel stage 666cc injecters along with a utec, fm, you know the usuals + a few
phil
~Phil
Old 12-21-2004, 07:07 AM
phil
thats it, i picked mine up 2nd hand for around 875.00
i will scan the dyno sheet whene i get a chance..
Old 12-21-2004, 02:49 PM
Thanks mate, every bit of info helps.
