Old 11-26-2004, 11:27 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
You all do know that gas line from the trunk goes from outside of the pass. seat right?
Run it from the other side.
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 11-26-2004, 11:37 AM
pavanbabut's Avatar
Originally posted by Earthworm
There's 6 full sections IIRC. Mine is a half section longer for some reason.
mine is having 5 full sections...
Old 11-26-2004, 11:51 AM
pavanbabut's Avatar
Hi Seraph,
Thanks for ur advice, actually thts a good idea too. But by now i have ran my wires thru center console and there is no problem in them. I think u r expert in aftermarket stereo installation, if u could please help me in reducing my alternator whining sound coming from my speakers.
Thanks,
Pavan.
Old 11-26-2004, 05:52 PM
pavanbabut's Avatar
Hi all,
How much it would cost for having wheel alignment for our vehicle, Anyone having idea?
Thanks,
Pavan.
Old 11-26-2004, 05:54 PM
Depends where you go. Probably anywhere between $40 and $80.
Old 11-26-2004, 06:05 PM
pavanbabut's Avatar
Thanks, thts good i thought it would run around 150$ as ours is AWD..
one more doubt, can i reduce my alternator whining sound from my speakers (When the ignition is 'on' and also when engine is running) by doin this mod.
http://www.scoobymods.com/forums/sho...=5062#post5062
THanks,
Pavan.
Old 11-27-2004, 08:19 PM
lee lee is offline
THanks,
Pavan.
No, the mod simply adds the capability for current to flow with less voltage drop.
If you have "alternator whine" with the key on, but engine NOT running, then it isn't alternatore whine - you have a different kind of signal issue, most likely still a grounding issue. Try running a long strand of wire from the stereo head unit, equalizer and amp all to one single place - no need to make it look good, this is just a test to see if the sound goes away.
Old 11-27-2004, 08:42 PM
pavanbabut's Avatar
Yeah i am getting tht whistling sound even when the engine is not running but just by turning on the key. This sound is increasing when i give acceleration. Ok i will try to do wht u told and let u know.
One more uestion i have posted it on 'General SVX babble', i have bought recently side marker lights, but i dont know how to install/fix them. I have read the thread on this issue, but want to know a detailed procedure of installin it.
If u can please give me suggestions on installin them
THanks,
Pavan.
