Old 11-08-2004, 05:42 PM
ilsegretosvx
tranny gone rebuild or swap
It just happened today, it does nothing, no movement nothing. Any thoughts...I was looking at Level 10 stuff but cant figure out whats what.
Old 11-08-2004, 05:50 PM
lee lee is offline
before you give it up, have you checked for codes. Was there any warning - did it happen while driving or when you first started out for the day from home/work. Also, here's a list of possible problems (assuming engine revs, but no movement).
Strainer (internal filter) plugged
Duty solenoid A failed
Control valve
Drive pinion broken
Hypoid gear
Axle shaft
Differential gear
Oil pump
Input shaft
Output shaft
Planetary gear
Drive plate
ATF level too low
Old 11-08-2004, 06:03 PM
ilsegretosvx
while driving...smooth as butter shifts then a little flare then nothing.......
Old 11-09-2004, 01:49 PM
my went not too long ago in my barcelona and it flared a little. then the flare got worse. eventually it lost 4th gear then started to loose 3rd all in 2 days. for it to crap out instantaiously sounds fishy
Old 11-09-2004, 02:02 PM
ilsegretosvx
well this afternoon I was able to get it in reverse and pull forward but with a whiney noise...its basically toast
Old 11-09-2004, 02:48 PM
n00b on demand's Avatar
I wonder if the problem could be computer related. I'm no tranny expert at all but i think when tranny's go out they show signs of wear and get worse.
Old 11-09-2004, 03:35 PM
No go.
Did you check the ATF level and colour, If it smells toasted, it probabley is. If not, it could be low fluid level or blocked strainer in the pan.
Old 11-09-2004, 03:40 PM
ilsegretosvx
oh yea, there is now a drip and a whiney noise....
this is why I have 2 SVXs....drive one while the other is getting fixed
Old 11-09-2004, 07:48 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
I know of a great
rebuilder in Huntingto Beach if it helps...
email me if you want his #......
Dayle
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 11-09-2004, 10:27 PM
5 speed?
Are you considering a 5-speed swap? It just looked like it in the title. anyway i hope u find an easy way out
Old 11-10-2004, 12:34 AM
ilsegretosvx
time and cash flow will tell...luckily I have the other SVX to drive so it might also depend if I let my daughter use it (shes getting her permit next month) she will not drive a stick...I dont want to be replacing clutches every year..
Old 11-10-2004, 09:25 AM
ahhhhhh gotcha, well whatever u do ,good luck in ur journey to save the SVX
