Old 11-04-2004, 07:19 AM
RobSVX
Cam Covers the same; left vs right ?
Hi,
I'm curious if the left and right gaskets are the same? I ordered both (did the drivers side last nite) and wanted to replace the passengers side, but they look the same and seem to have the same part # from the place I got them (not subaruparts.com) ?
Anyone know ? The cam covers look the same, but don't want to get it off and not fit !!!
Old 11-04-2004, 09:16 AM
they are similar but not the same. it has been a while since i did mine but i am pretty syre there is a lsight difference in the front portion of the seal.
Old 11-04-2004, 09:50 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
http://www.subaruparts.com/diag/?mod...ategory=020A-1
shows different part numbers for left and right.
Old 11-04-2004, 11:23 AM
RobSVX
Yes it does, but sometimes they'll label parts this way. The reason I'm questioning what I got was because I ordered two part numbers and got 2 of 1 part #.
Anyone know which head is left and which is right ?
facing car ?
Sitting in car ?
I need the Passenger side adn not sure which it is ?
Old 11-04-2004, 01:20 PM
right=passenger side
left=driver's side.
The easier way to tell is make judgment from sitting in the car.
Old 11-18-2004, 08:53 AM
RobSVX
Well, I re-ordered the Passenger Side (Right Side) from Subaruparts.com and it came back with the same part# as the Driver Side (Left Side) ?
I'll assume they're either the same or just the parts labeling is screwy. There are a few different numbers on them, but the main part# and description matches both sides.
Old 11-18-2004, 12:28 PM
red95svx
Take a closer look. The part numbers should be 1 digit different for left and right: 13270AA031 and 13272AA031.
Did you remember to get spark plug gaskets and new bolt grommets??
Old 11-18-2004, 12:43 PM
they are different. i just did mine and the right i believe has a flat spot on the gear cover as the left is rounded all the way around. the gaskets are different
Old 11-20-2004, 03:59 PM
RobSVX
13270AA031 is what I've got
The way you wrote t his, looks like the 13270..is the LEFT side (Drivers I think) ?
I have two of these: 13270AA031 from SubaruParts.com.
It says :Gskt-Rocker CoverRH. Would the RH mean right side and thus the passenger side.
I'm needing the Passenger side gasket, so hope this is it.
I really don't want to tear about the car and have the wrong one. Yes, I've got the other gaskets.
Old 11-21-2004, 08:40 AM
red95svx
Re: 13270AA031 is what I've got
Actually I just wrote the numbers randomly. Sorry. I should have been more clear. 13270AA031 is the passenger side.
Old 11-21-2004, 07:55 PM
just look at them. the right(passenger side) has a flat spot a the front of the engine this is how u would know.
