Old 10-28-2004, 09:16 AM
rob_4187's Avatar
rob_4187 rob_4187 is offline
You're mine!!
Send a message via AIM to rob_4187
92 SVX's 4WD?
Why does my insurance say that my car is 4WD? They said 92's are 4WD and other models are AWD and if i were to get a newer AWD model my insurance would be $60 more... i have driven both and i didnt notice a difference in handling or anything.
Teal 92 SVX LS L with 103k
Engine: Stage 1, 3 in filter with heat sheild, underdrive pulley, NOS fogger system (75 shot)to be installed soon Sound:1 10" infinity with 230 continuous watt Dual amp (we have small trunks)
Old 10-28-2004, 09:22 AM
THAWA
Because your insurance company is run by people that are idiots. And by idiots I mean people that'll just say anything on the specs of a car.
Old 10-28-2004, 09:30 AM
red95svx
4WD, AWD, quattro, all-road,........different names, same basic concept. The SVX is AWD, but I've also seen it described as having "full time 4WD". 6 of one, half dozen of the other. Tell your insurance company to smarten up Your AWD system is identical to the AWD system in any other SVX.
Old 10-28-2004, 10:59 AM
When I checked out insurance at AIG, a company I had for years, they told me insurance on my (Nicks) 96 SVX was higher than my 92 SVX, (both awd models with the same equipment execpt his has two airbags) because it was a sports model?!?!
Wiskey Tango Foxtrot.
Old 10-28-2004, 02:01 PM
red95svx
Any time you have two indentical cars built in different years the newer one (since it is worth more) will cost more to insure.
Old 10-28-2004, 03:29 PM
Dave, this was for comprehensive only, deer hits, hail, acts of God. I explained that they had the same engine, hp, abs, awd, fenders, doors, it just did'nt matter, "That one has a higher rating." Tom
Old 10-28-2004, 04:16 PM
And you're complaining why??
I also wouldn't say that AWD = 4WD. I would say the Justy was 4WD since the center differential doen't slip. You're either at 100/0 or 50/50 distribution.
Old 10-28-2004, 10:46 PM
THAWA
AWD and 4WD as we usually think of them are not the same
Old 10-29-2004, 05:38 AM
red95svx
Comprehensive Insurance is based on the value of the car. The 96 simply has more value than the 92. More value = more expensive to insure.
Old 10-29-2004, 05:40 AM
red95svx
Right. That's why I referred to them as having the same basic concept (all four wheels being driven). They aren't indentical, just similar.
Old 11-02-2004, 05:44 PM
NapaBavarian's Avatar
Good morning!
All wheel drive has some sort of a diferential in the middle allowing all 4 wheels to stay engaged all the time, 4WD has no diff so it can only be used on low traction roads.
Also, a 1988 BMW 325is with 170hp is significantly more expensive to insure than a 1997 M3 with 250hp... Go figure
.Karl.
Old 11-03-2004, 12:06 AM
the one w/ dual air bags sgould be cheaper. this is because even w/ liability, there is medical coverage up to a certain amount. there is less risk in a car w/ airbags cuz they are supposed to help in the event of an accident.
