Old 11-09-2004, 07:37 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Are you certain it isn't just tire noise? Some tires are horrible noise generators and can sound like a 747 climbing up your tailpipe. Four wheels in the air with tires spinning and using a stethoscope would be prudent before deciding that the bearings are at fault.
Old 11-15-2004, 04:51 PM
The Molinator
Bearings ......OR ???????
Beav: Thanks! That's a good idea!
I can tell you this....It's getting worse ...almost daily....which is scaring me, of course! Could it be an axle? Can't be tire noise....cuz it's getting worser (I no!) all the time! I already have a set of rear bearings from SubaruParts.com, but I haven't had time to install (at least the passenger side, which is where major noise is coming from). I had a problem with the seat belt on the same rear passenger location (jammed)>> I took it apart, got it to work...BUT didn't seem to make the right noises (vibrates too!), so ordered one new, but haven't received yet. When the bearing on that side is noisey, the seat belt unit (ball bearings in there for something, right?) really vibrates and buzzes too!???
HELP!
Thanks for your help guys!
Jim
Old 11-17-2004, 05:21 PM
neffer neffer is offline
Send a message via Yahoo to neffer
Whenever u replace the rear bearing spend the extra money and replace the hub. If not you will be replacing it again.
Old 11-17-2004, 06:10 PM
The Molinator
HUB TOO!........?
Is that the consensus here, guys?.....REPLACE THE HUB!?
let me know.....I'll look up the price.....
Jim
Old 11-17-2004, 07:03 PM
The hub should be replaced only if bearings keep wearing out.
This is of course if the bearings were installed correctly in the first place.
Old 11-17-2004, 07:42 PM
Beav's Avatar
Not as old as Randy
I fail to see the logic of replacing the hub. It is easy to measure once disassembled, if there is reason to think it may be damaged. Personally I'd be more concerned about the knuckle being distorted, the hub is a pretty stout item and not easily distorted. Normal reason for replacing a hub is the land that the outboard inner race sits on can become undersized. A very easily seen worn area results and is common to many cars. I have to say that I have never seen it occur on an SVX, but then again, I've not seen everything...
Old 11-24-2004, 12:46 PM
maroon menace
okay enough of this,
the wheel bolts are attached to a flange that fits onto the splined end of the axel. the disk brake and the wheel are carried on this flange or hub. there is no physical connection between the flange and the spidle carrier that contains the wheel bearings. the axle passes through the spindle carrier and rides on the bearings. The hub is attached to the axel by a nut that must be tightened to the correct torque or the bearings willl fail. the load that the wheel/axel carries is passed on to the vehicle body through the wheel bearings to the spindel carrier to the strut.
Nothing you can do to the wheel bolts (lug nuts) will effect the bearings!
What you can do with great difficulty is distort the brake disk by over tightening without a cross sequence with an air gun. more common with drums than with disks though.
Old 11-24-2004, 02:08 PM
n00b on demand's Avatar
You said you bought new tires.....couldnt it be the tires that are causing the noise? I remember reading that on subarusvx.com.......that it might be tires instead of bearings.
Old 11-24-2004, 04:09 PM
The Molinator
Hankook [K102 ???]
I'm not sure model # [K102?], but I put Hankook tires on right before this bearing-type noise started (and has gotten much worse!)..... [like I said, they used air wrench this time ...instead of torque wrench!]
Is this V-rated (W speed) tire OK for tire noise? I assume so, since these tires were highly recommended on this Website.....
SOOooo...., Beav, should I replace the upright (knuckle) since I replaced this rear bearing about 2 years ago.....???
I'm gonna replace the rear bearing(s) for sure.....I only wonder if I should replace the upright on the noisey side...?
Gotta check SubaruParts.com for price now....
THANKS Y'ALL for your input...
Jim
