Old 10-24-2004, 01:41 PM
NiftySVX NiftySVX is offline
Awd
Hey guys
Anyone ever have a problem with thier SVX tranny where it feels like the rear wheels aren't being driven and the front wheels will spin excessively?
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 10-24-2004, 01:44 PM
Phoenix_3737's Avatar
Phoenix_3737 Phoenix_3737 is offline
i dont know much about this but ive heard of people putting a fuse in the FWD box in the fuse box in the engine compartment and it made them spin excessively
1994 Pearl LS Black top ( The Penguin)
"was" The only man alive who drives a "Suba SSV".......according to my insurance company
***sold***
"was" The Only Subaru Svx Owner in Laredo Tx., or maybe atleast only owner registered here....
http://www.cardomain.com/id/phoenix_3737
Old 10-24-2004, 04:52 PM
Re: Awd
Originally posted by NiftySVX
Hey guys
Yep there have been a few. The Transfer clutch valving sticks, or the C solenoid fails to work, this will prevent the clutch from operating to stop front wheel spin, by engaging the rear wheels.
You could check that the FWD fuse is not inserted in the under hood fuse box.
The Transfer clutch housing can be removed from the back of the box to replace the C solenoid valve assemble and the clutch plates.
Till you fix it ,DON'T SPIN THE FRONT WHEELS, IT CAN CAUSE THE FRONT DIFF TO BREAK.
Old 10-24-2004, 06:13 PM
Duty Solenoid C
I have no space in the fusebox for a fwd fuse because I converted this car from FWD. I had to custom make the harness for the AT OIL TEMP and FWD lights and the FWD switch. I Have a replacement duty solenoid C, I just haven't put it in yet. I hope it will fix it tho, it was a 90 dollar part. The TCU should detect a siezure of solenoid c according to the subaru RM. anyone out there replaced duty solenoid c and/or the transfer control valve?
NiftySVX
Old 10-24-2004, 08:11 PM
lee lee is offline
replacing the solenoid isn't overly hard, just time consuming - have to pull the driveshaft and take off the transfer case housing - careful the wires aren't too long. The search button is your friend - try "solenoid and transfer".
But, have you done a pressure test on the AWD section? It could be the solenoid is working fine, but the plates are worn over time - and worsened by differing tire sizes/pressures not set correctly.
if you have a good internet connection download the tranny manual in my locker. part 2 has disassembly instructions, part 3 has assembly. BTW, I have not personally done this repair so your use of the words & pics in the manual is at your own risk.
Old 10-25-2004, 05:26 PM
Re: Duty Solenoid C
NiftySVX
Just to get this right. You fitted a AWD box and rear end to a FWD car. I assume that you fitted a AWD TCU also?
Old 10-25-2004, 06:03 PM
AWD
I do have an awd TCU and I have tested the transfer pressure.
It won't be the first time I have had a 4EAT apart, and I own the service manuals. The transfer pressure is 0 untill wheel slippage occurs, then it jumps up and then falls back to zero. I was wondering if the MP-T was worn. Just curious if anyone else has had a similar issue.
Thanks,
NiftySVX
