Shuddering when TC locks up
Everytime the TC locks up above 50mph, i feel a shuddering/vibration in the car. This happens only when the rpms are dropping while the transmission goes from 4th to TC lockup. Once the rpms have stabilized, there is no more vibration/shuddering. I do not notice this on any other shifts (up or down).
I don't know if this is related in anyway, but i recently changed the high pressure hose for the power steering. I started noticing the vibration/shuddering after the change. I've done a few searches through the forums but couldn't find anything related. Thanks RB |
Huh... How coincidental! I also have a 94 FWD Barcelona Red SVX with about 142k on the odo. Cool!
Anyway, mine does the same thing when the TC locks up. You won't feel the shudder any other time because it is the actual locking/unlocking process that causes the shudder, and the TC only locks in 4th. Mine only does it when in the 48 - 55 mph range, when in 4th gear, and when I press or release the accelerator. This also only happens when the car is warm. My car has been doing it since I bought it (Aug. 03), and so far there are no ill effects. I'm pretty used to the shudder feeling, but if it starts bothering you... Just put the selector into 3rd. In the 45 - 55 mph range this will only raise your RPMs by a few hundred. Most members here will actually suggest that you keep the selector in 3rd up until 80 kph, which is about 50 mph. Last edited by deruvian; 10-14-2004 at 04:25 PM. |
I miss the days when my car used to be smooth as silk
Don't we all.
If the car is shuddering when the TC locks, it might be a torn rear tranny mount. I think its pretty easy to see if you can get under the car.
The tranny mount can be done in a garage on jack stands. I have done it. The exhaust has to come down.
I personally don't think it's the tranny mount causing this. If it was then it wouldn't matter which gear you are in.
You mention this starting shortly after replacing the high pressure power steering hose...did you check your steering fluid level? Where do you feel the shuddering? In the steering wheel or in your butt?
Power steering level looks fine. The vibration is in the buh-tox almost like the whole car shakes.
I'll find out for sure tonight. If so I have the camcorder.
